Door handle harness micro switch backwards????
sorka
7,618
5,645
Merced, CA
I got a replacement microswitch harness on ebay. My existing harness appears to be fine but since I was replacing the paddle gear I figured I do this at the same time.
But it appears one of the switches has the pigtail wired backwards. Here's a picture. Factory microswitch on left and aftermarket ebay one on right:
The replacement has the wire pointing up in the opposite direction. I thought maybe it was some sort of modified routing except that their own picture which HAS a modified routing example shows their own harness microswitch pigtail pointing down, not up.
Anyone buy a third party harness that looks like mine?
sorka
7,618
5,645
Merced, CA
The seller said I should just install it backwards and bend the wire 180 degrees. Given my factory harness is still fine and I was only just doing a proactive replacement since I had it all apart, I'm not going to do what they suggested.
KalJoMoS
275
173
EETN, EST
These switches are designed to accommodate different scenarios so you ended up with wrong/different part. Panasonic have them listed as LH/RH and contact/actuator wise, a little clarification on the photo attached
Reactions: outdoors and sorka
