Hello All,
I have found myself in a situation where one of my door handles (passenger backseat) will not present on my 2015 MS (Gen 2 Handle). So of course common failure mode right? So I took my door handle apart. DIY was pretty simple and to my surprise everything was intact, Paddle was in great shape and so were the micro switches. I ordered the repair kit from EV tuning and replaced everything anyway. Hooked the door back up and nothing, door handle still not operating. Only thing that happens is the LED light flashes once when the door handle harness is connected to the door frame harness. So by this time I am thinking 1 of 3 things could have failed. Either the door handle motor, the lock switch control module in the door handle, or the actual Door harness. I took a volt Meter to the door harness and i see between 10 to 12 volts coming out of the door itself so i am thinking the problem is within the handle components. Does anyone have any tips on troubleshooting or know what Voltage reading i should be seeing from the lock switch control module whenever the door handle is supposed to operate?
