Door Handles Don't Open When Touched?
Discussion in 'Model S' started by Yankee, Oct 5, 2017.
Tags:
  1. Yankee
    Yankee New Member
    Thousand Oaks, CA
    I'm curious to know if I'm alone here. I took delivery of a new 75D less than two weeks ago, and I love the car so far. But, for the life of me, I can't get the door handles to open upon touch. They do open as I approach the car, and when I double press on the fob, but pressing on any door handle (with the fob in my pocket) does nothing to open them if they're closed.
    I've read the manual up and down, but no clues there. I've been searching around here, and I've found a couple of old threads like this one, but not much about modern models having the problem:
    Door handle not working
    Seems like a trip to the service center is what I need, but I wanted to post here first just in case there's a lead on the issue that I hadn't yet considered.
  2. d21mike
    d21mike Member
    Torrance, CA 90503
    I read another thread where it said you have to PRESS harder then you think. Like it was changed recently for some reason. I got my car on 9/28 and sometimes it seems like it is not working. But then it does. So, not sure what is happening. I think if it does not work I PRESS harder and it does. I would need to test more.
  3. murphyS90D
    murphyS90D Member
    Horsham, PA
    Do you have a cellphone in the same pocket as the fob? That makes it really hard for the fob to hear the car.
  4. Yankee
    Yankee New Member
    Thousand Oaks, CA
    mike - Good tip on pushing harder. I will that one more time, although I already feel like I'm punishing the handle!
    murphy - I've done it with a phone on me and without one. Never works either way.
  5. UberEV1
    UberEV1 Member
    San Jose, CA
    In my experience on the 2013 S85, the open-on-touch only seems to work on the front door handles. So I tend to touch the front door handle even when I simply want to open one of the rear doors.
  6. Yankee
    Yankee New Member
    Thousand Oaks, CA
    That makes sense. Unfortunately, even mashing the driver's door handle does nothing. :(
  7. Protone
    Protone Member
    Finland
    I have 10/2016 MS, and I have had 2 of the handles changed because they didn’t respond to touch. Both times they said it was a broken pressure sensor, and they replaced the whole handle, not just the sensor.
  8. ccdisce
    ccdisce Member
    Georgia USA
    After I took delivery 28/09/2017 my words to Nick my Delivery Specialist were " pressed the door handle but it wont open" his words were " "Press con Gusto" he came over and did that and it opened.
    I know my for sure that my lightweight wife will NOT be able to open it by pressing the handle so I plan to give her the spare 'key' and program the handles to auto present on unlock in her profile otherwise she will have to do the double-click dance.
  9. 1MoreUsername
    1MoreUsername Member
    Columbus, OH
    Yes- confirmed: Model S Delivery Update
    It takes enough force to make me worried about breaking them.
  10. ccdisce
    ccdisce Member
    Georgia USA
    I agree that the force is too high as I sometimes takes me 2 thumbs to open the door so the plan 'going forward' as is that worn out cliche' goes is to ask the Service Center folks to have a look at it along with a vibration in the LH front suspension.
    in the videos that I have seen on YouTube an single 'medium' press with the 2nd finger should make the door handle present itself.
  11. croman
    croman Active Member
    Chicago, IL
    I think this changed with the "passive entry" update. It used to be much easier and consistent. Also there are options about how the handles retract and open in the car settings that might be causing an issue. Check them out.
    It works well for me (I don't think it requires that much force at all to press them in to get them to open).
  12. johnster007
    johnster007 Member
    Minneapolis, MN
    #12 johnster007, Oct 6, 2017
    I just took delivery too. I think the trick is to press front and then rear driver's side handle. Maybe an extra security measure. It's different than my "classic" car. Let me know it it works!
  13. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    Sounds like my wife...
  14. eddy009
    eddy009 Member
    I've recently took delivery of my Model S 75D October 2017 build. I'm confused on how the self presenting rear door handles work on touch. My driver side handle will present itself, but when I press the rear handle nothing happens. I've even given it a firm push and it stays retracted. This is happening on both rear door handles. I've also noticed sometimes the front passenger door will stay retracted on a hard firm push. My setting are:
    Door unlock Mode - Driver
    Walk Away Door Lock - On
    Unlock Park - On
    Child Protection Lock - Off
    Auto Present Handles - On
    Passive Entry (Grayed Out) - On
    Am I doing something wrong?
    Thanks
  15. murphyS90D
    murphyS90D Member
    Horsham, PA
    "Door unlock Mode - Driver"
    Only the driver door is unlocked.
  16. eddy009
    eddy009 Member
    I found out from Reddit. Basically just have it self present all door handles. If I idle around the car and the handles retract I can touch the rear door handles and they will present just like the front handles because they became unlocked like the front door handles.
  17. murphyS90D
    murphyS90D Member
    Horsham, PA
    The whole point of only unlocking the driver door is for safety to guarantee you can get in the car and not worry about some bad person getting in one of the other three doors. This feature was added in 2015 or 2016.
