Door or window problems :(
Den4eG
7
2
Russia
Driver door window retracts on opening but rolls up immediately so I can not shut the door after exiting. I re-calibrating the window! But problems stayed :( Please help,how tifix this problem? I can upload video
KenC
3,551
3,212
Maine
Something seems off, it hit the top quite hard. I'd take off the door panel, and look at the regulator. Make sure, all the pieces are in place. There's a plastic circular piece that has fallen out of other people's regulators.
toolman335
842
595
Rochester
I had a somewhat similar issue soon after I bought the car 13 months ago.
It ended up being a wire that was assembled incorrectly at the factory. You might have a similar issue. Roadside service couldn't fix it.
Den4eG
7
2
Russia
[QUOTE = "calidreamz808, post: 5095589, member: 104479"] ....... Позвонить в службу поддержки? Может быть, записаться на прием? [/ QUOTE]
Noo (
Den4eG
7
2
Russia
Ok, i try to take off my door panel
P3dStealth
928
991
I'm confused? Why are you rolling up your window with the door open?
Did you calibrate the window with the door closed?
Den4eG
7
2
Russia
[QUOTE = "P3dStealth, post: 5095841, member: 120220"] Я запуталась? Почему ты закатываешь окно с открытой дверью?
Калибровали окно при закрытой двери? [/ QUOTE]
one more video. window up when door open,
on the screen shows that the door is closed
P3dStealth
928
991
Ohhhhh. The car thinks your door is closed.
The closed door switch is build into the latch on these cars.
Send a pic of your door latch. The part that clicks into the silver retainer when you close. It should be open. I can open and close mine with my hand and the car will think the door is closed.
Den4eG
7
2
Russia
That's not his problem. His door is open and the screen says it's closed. The car is actually going to the window closed position.
His latch is closed or broken.
I did glass tint a week ago, they blocked the lock, but then it worked. For almost a week, the car was updated at night and it seems after that the door stopped working:( one more video
toolman335
842
595
Rochester
Yup mine did this. Wiring issue made car go beserk. It was especially bad when it rained or I went through a carwash. I was convinced the car was a Gremlin and couldn't handle the touch of water.
Sometimes the car would think the doors were open when they weren't, and vice versa. It ended up damaging the window frame so they replaced that under warranty too.
Den4eG
7
2
Russia
Friends!!! thank you very much for your answers!
I found what is the problem, in this smal f*cking laaaaamp! she was not connected and Tesla thought the car was closed. I connected this one and window works as it should :) wow cool
Reactions: KenC and toolman335
