Doors Unlock slow...auto present of handles not very speedy
Discussion in 'Model S: User Interface' started by jlucero, Jul 20, 2015.
  1. jlucero
    jlucero Member
    DALLAS
    running 6.1, i find that sometimes i walk up to the car and the handles dont present themselves for 5 seconds. and sometimes they dont present themselves at all and i have to get the key fob and press the roof. what gives?
  2. jeffro01
    jeffro01 Active Member
    Teller County CO
    Weak\dying key fob battery?
    Jeff
  3. Barry
    Barry Active Member
    Colorado
    Are you approaching the car from the front? that's where the sensor is.
    I pull head-in to my garage parking spot and approach the car from the rear, as there's a wall in the front. I always have to use to button on the fob to get the handles to present.
  4. Paul Carter
    Paul Carter Active Member
    Canada
    Also make sure that the fob isn't in your pocket next to your phone, wallet, or foiled things (e.g. gum/etc..). That seems to delay or completely prevent your fob from getting recognized.
  5. jlucero
    jlucero Member
    DALLAS
    thanks---i didnt know about the front/rear thing, and didnt know that it cant be in your pocket. it is always in my pocket...
    on average, when most of you guys walk up to the car, do the handles open as you walk up? or do you have to stop and wait a bit for the handles to come out?
  6. Paul Carter
    Canada
    It can be in your pocket, just certain things near it can mess with it. Angle of approach is also a factor.
  7. tezzla
    tezzla Supporting Member
    SoCal
    If I approach from the front, the door handles are out before I get to the door.
  8. smilepak
    smilepak Active Member
    Eastvale, CA
    I turn that feature off. I find it is annoying and add wear and tear unnecessary. I have the key fob in my pocket most of the time. As I walk around, like my garage or near it, the car present the handle.
    So now, with that turned off, I just walk up to the car and tap the handle when I truly need to get into the car.
  9. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    1. If the 5 second delay is occasional, it's due to the computer doing some processing. Should be pretty rare though. If it's a) frequent b) you have a 5 second delay even after walking right up next to the door, and c) there's nothing in the key fob pocket to disturb the signal such as a cell phone, first replace your key fob battery. If it doesn't change, get it looked at by Tesla service.
    2. For the "sometimes never come out", are you aware that after a certain period of inactivity the auto-presenting door handle feature disables in order to save energy? (I believe it's 24 hrs or 48 hrs without disturbing the car...it's in the manual somewhere).
  10. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    As others have mentioned, approaching the car from the front definitely gets the key recognized earlier (from farther away). Approaching from the back, you'd have to stand directly in front of the front door (either one) before it will present. And if you walk fast, you will have to wait like 1 or two seconds if you are coming from the rear. I just walk slower and stick my hand out for the handle to meet it. If I am trying to open the rear door, I have to do the "Tesla 2-step shuffle" -- 2 steps to the front door, handles present, 2 steps back to the rear door, open door.
  11. supratachophobia
    supratachophobia Active Member
    Columbus, Ohio
    I noticed that on phones with NFC, it can cause a delay or flat out not work if they are in the same pocket.
