Dots above USB ports
Discussion in 'Model S: Interior & Exterior' started by B-Chicago, Jul 29, 2013.
  1. B-Chicago
    B-Chicago Member
    Chicago
    Does anyone know what this circle of dots above the USB ports is for? My SC had no idea and said they just noticed the newer models had them, but didn't know why. They must be there for a reason. I am Vin 13,XXX.
  2. mknox
    mknox Well-Known Member
    Toronto, ON
    I wonder if it is an opening for the internal vehicle temperature sensor. I've had cars with these (in various locations) in the past. There would be a small fan to draw air in and over a temp sensor. My car doesn't have this, and there have been issues reported about HVAC performance and internal temperature reporting (on the mobile app) that seem out of whack. Earlier cars may have just had a sensor with no fan, and would be susceptible to error from the temperature of the material it is attached to or is near to it radiating heat.
  3. Denarius
    Denarius Active Member
    Utah
    I have 13201, with the hole. With the climate control on I can feel slight air current pulling into it. I think mknox is probably correct.
  4. garcilamd
    garcilamd Member
    Miami, FL
    I read somewhere that the car's computer is here. That is why the armrests do not lift into storage. I agree that it can be some sort of ventilation but not really sure.
  5. cinergi
    cinergi Active Member
    MA
    Having seen the car in pieces at the factory (while it was shut down, so I could actually get up close and personal), I can tell you there's *nothing* below the armrests other than vents and the wires for the USB/12v. It's deceivingly full.
  6. mknox
    Toronto, ON
    Hmmm. Wonder if someone could modify the sliding armrests so they hinge open, and mount some sort of storage bucket in this otherwise unused space?
  7. cinergi
    MA
    Sorry -- I meant to indicate there's no room for anything else in that armrest. It's very deceiving.
  8. olanmills
    olanmills Member
    And I think cinergi was trying to say that there is no computer or anything like that there, just conduits (both for air and bits, lol).
  9. mknox
    Toronto, ON
    Ahhh... to bad, because it looks like a wasted opportunity for some much needed interior storage.
  10. twinklejet
    twinklejet Member
    Singapore
    Opening for temperature sensor... Or a bee hive...
  11. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    My MS60 does not have said holes.
  12. B-Chicago
    B-Chicago Member
    Chicago
    I guess the beehive was a recent upgrade.
  13. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    upgrade to what though? tis is the question ...
  14. AC1K
    AC1K Member
    Calgary Alberta Canada
    its a little fan, it spins with HVAC on and stops when HVAC is off. also there is a light behind the USB port, that light is NOT from my flashlight.
  15. mknox
    Toronto, ON
    As I postulated earlier in this thread, it's an aspirator for the HVAC's internal temperature sensor.
  16. JPP
    JPP Active Member
    SF Bay Area, CA
    OK--so for those of us who do not have the holes, do we not have the same electronics in the center console/armrest? Do we have an HVAC sensor there?
  17. mknox
    Toronto, ON
    There has to be an HVAC temp sensor, but I think its location is a mystery. Every prior car I've owned with auto temp control has had an internal temp sensor with an aspirator except my Model S. I think the current sensor is buried somewhere and it gets "influenced" by the temperature of the materials surrounding it. I find that I have to keep my HVAC set at 68 or 69 degrees just to maintain comfort and my iPhone app will often show the car's internal temperature way higher than I know it to be. I think the addition of this aspirator will help.
  18. B-Chicago
    B-Chicago Member
    Chicago
    I was just at the Chicago SC. They were not 100% sure but also thought it was the HVAC temp sensor and said previously it was located in the front dash somewhere. I was in a loaner with VIN 10k and no holes. My VIN is 13k with. Change was made sometime in that period.
