Double vision (ghosting) at night through windshield?
Discussion in 'Model X: Interior & Exterior' started by rmiggins, Jan 19, 2016.
  1. dwebb66
    dwebb66 Member
    Ladera Ranch, CA
    The relative angle of the windshield would also be a factor.
  2. mfel
    mfel Member
    PacNW
    #42 mfel, Apr 7, 2016
    Like vandacca said. Any time light goes across an interface like air/glass or glass/air, there's a slight reflection. Purposeful optics like camera lens and binoculars use all sorts of fancy coatings to reduce that behavior.
    So if the glass is at an angle, the reflection off the second glass/air crossing (ie the one into car) keeps a fraction of the light inside the glass which then zigs upwards (given typical slope of windshield) to the outside glass/air which it does same thing again but returns to same original direction, and most of that then enters car offset slightly from original ray. THe process repeats and you'll get many multiples but each is only a few percent as strong as the primary ray.
    I looked last night and saw it clearly on my Model S when I knew what I was looking for. Usually people just tune it out.
    Hmnm, I haven't tried it, but you might take one of those laser pointers and have someone shine it into car onto piece of paper and then look at what happens. I bet you'll see a set of dots.
    And there's no way to 'fix' this short of putting anti-reflection coatings on entire windshield. Its a fundamental property of optics, and has been happening on all windshields since they were invented. Though there might be something with the Model X's unique windshield to make it more noticeable.
  3. Mark Z
    Mark Z Active Member
    North Orange County
    Model X owners who don't think the windshield is reflective can shine a flashlight towards the sides. From the front seat, you will see the wires and bolts reflected from the inside of the pillars. The direct view from the front of Model X is even more revealing. Nothing is hidden.
  4. greg t
    greg t Member
    gilroy
    • Informative x 2
  5. vandacca
    vandacca ReActive Member
    Hamilton
    Thanks for the great diagram @mfel. Yet another variable in the thickness of the windscreen. The thicker the windscreen, the greater the separation. I suspect that one reason for the more pronounced effect on the Model-X is that the big windscreen has to be thicker for safety, plus the steep angle for aerodynamics.
    Anyway, there may be an anti-reflective coating that may help to minimize the effect.
  6. Roentgen
    Roentgen Member
    Southern California
    New Model X owner here, took delivery 3/30. Not sure I would have noticed if I hadn't seen the title of this thread. Thanks guys! :/
    But can confirm the same, and I pointed it out to my wife too, who may also be unable to unsee now... Kinda eager to see how this goes...
  7. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    Congrats! Did you notice any other quality issues with your X? Did you get a sunshade?
  8. Roentgen
    Roentgen Member
    Southern California
    Thanks!
    No sunshade, but confirmed with rep that I would eventually be getting it. Only other issue I'm experiencing is the driver side middle seat doesn't move forward like it should for 3rd row access, but I'm thinking this may be due to a car seat issue...
    Reading more of this forum tho, is opening my eyes to other potential issues... ignorance is bliss....
  9. millertime
    millertime Member
    Cupertino, CA
    I also experience this double/triple image with bright lights, most obvious in low light driving. The thickness and multi-layer construction of the windshield may be the problem. Here's hoping someone clever has a solution. It's quite annoying.
  10. Roentgen
    Roentgen Member
    Southern California
    Can anyone who has tinted their front windshield say whether this improves or worsens the effect? Thinking about getting Photosync on the front.
    Interestingly, the shop I asked for a quote from said they have done several Model Xs, and they require a waiver for the front windshield application; they say other shops have cracked it during install, and that they are not sure of the structural integrity due to size and curvature.
  11. FA1820
    FA1820 Member
    Palo Alto, Ca
    Hello all,
    Here is the latest update: I stopped by my local SC in PA today and spoke to one of the SC mangers who told me that the issue had been elevated to an internal topic @ Tesla. He also said he was able to see the problem himself during low daylight on another model X. I offered to loan my car back to Tesla in case they needed to have a real subject for night time problem testing. Bottom line is that 10- Tesla acknowledged there was a problem 2)- there were a few more faulty windsheilds out there and 3)- they had pulled the record for my car's windsheild to see where it took them. After I heard that they would be looking for a permanent fix, I decided to hold off on a replacement request at this point and get one at the time of my first appointment with Tesla at the end of April.
    One final note: not all ModelX windsheilds are affected; most likely Tesla will be looking for common denominator among the reported cases. I strongly suggest that you let Tesla know immediately if your car is affected. Hopefully this enables them to identify the bad batch (design/manufacturing/material flow) fast. Otherwise, we will be getting windshields after windshields and it will be a random luck of the draw when we end up with a "normal' one.
    Thanks,
    Farzi
  12. eleXtrons
    eleXtrons Member
    Has anyone definitively confirmed that there exists Model X windshields *without* this problem? (ie has someone who knows the problem and can see the problem ever seen a windshield without the artifact?) I also picked up my car at Palo Alto, so I will register my desire to get a new windshield (after redesign).
  13. proven
    proven Member
    Raleigh, NC
    I haven't noticed double vision yet, but I haven't looked for it either. I'm not sure I want to!
  14. WilliamZ
    WilliamZ Member
    San Clemente, CA
    I got a bad feeling about this. So, if you add the sunshade that Teala provided, will the issue go away?
  15. FA1820
    FA1820 Member
    Palo Alto, Ca
    I have not received a sunshade from Tesla. This seems to be a production/manufacturing/engineering defect, not sure how the triple light refraction within the glass layers can be avoided by using the sunshade.
  16. FA1820
    FA1820 Member
    Palo Alto, Ca
    @proven, It is impossible to miss the light effect at night when cars are approaching on the other side, specially on a two way street. The same goes for the traffic lights. If you look at the pictures posted, you'll see what we see. So it seems to me that you have one that functions as designed. I also don't believe it is a bad engineering, I am more inclined to think it is a bad manufacturing batch. Not all cars would be affected, otherwise it would have been noticed by Tesla's team.
  17. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    What has been seen can never be unseen. :)
    FWIW even after I was aware of it, I or my wife never noticed it. I have not told her about it yet and I only started to look for it when I was bored and sitting at a supercharger the other night and saw it in the street lights. Seemed to me to be more pronounced at the edges of the glass. Did not notice it or my brain filtered it out in the direct viewing area.
    So now I am going to have to spend all of my night driving time staring down these abhorrent images.:mad:
  18. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    Do a Google search for "double vision windshield". The first page of results includes reports from owners of the following vehicles:
    Toyota 4Runner
    Chevrolet Camaro
    Toyota Prius
    BMW 335i
    Chevy SS
    Audi A5
    Chevy Corvette
  19. FA1820
    FA1820 Member
    Palo Alto, Ca
    @aesculus, seems you have a perfect car. :)
  20. FA1820
    FA1820 Member
    Palo Alto, Ca
    @millertime, please take picture and report this issue to Tesla, if it is distracting enough that you'd want to ask for a replacement.
