And this proves exactly what? If you actually do the math correctly, it is less than ,55mph ,a not 65,and there is a huge difference between 65 and 55 in wind resistance and not so much between 55 and 45. For example.
But even so, you mainly prooved the point, since an AWD would've been closer to 22Wh/mi on that run and an RWD closer to 20.
And you basically spent 10,000$ more just to drive the car with 60mph flat with AP on... And maybe, just maybe, floor it once or twice. To each their own, Tesla will love you. But if you are going out of the way and 10-15,000$ is a lot of money to you go with AWD or RWD.
That is my sound advice.
It 'PROVES' nothing, it is 'INDICATIVE' that the P3D+ can be driven efficiently, and isn't hugely worse than the AWD. It's also 'INDICATIVE' that the way you drive the car has a much bigger effect on efficiency than the differences between the cars.
And you have 'NO IDEA' (and nether to I) what an AWD or RWD on that run. It's just indicative, that a P3D, can be driven to close to the EPA range under 'normal' rather than 'controlled lab conditions'.
Also, you do know that the EPA figures for range/empg is based on a 48mph average on the freeway cycle, with a Max speed of 60 (briefly)
If you do the maths 'Correctly' the average speed for the whole trip is '56mph' by the ODO on the car. However for this post, I simplified the calculations, discarding the standstill, parking and local traffic mileage on the way to the freeway, out of the calculation of average speed, and used an independent GPS tracking app on my phone. Yes, this wasn't clear fro this post, And on this trip, during the day, with traffic, on freeways with 55 and 65 mph limits (and 25/35mpg local roads with lights on the way to the freeway). I was also 2 minutes EARLY for my planned arrival time, I didn't need to go any faster. Also, the route has approx 2000ft of climbing (and the same descending, as it's a circular route.)
So, the route is faster than the EPA average, has many more ascents/descents than the EPA standard, and has some mix of city driving in it as well.
You can also see, that the last 30miles hit average of 222Wh/mi, which is significantly under the Rated rate (which is the solid line on the graph)
Still doesn't PROVE anything, but it's indicative that there isn't a 20% (50Wh/mi) difference from the AWD. You think a AWD would be averaging 187Wh/mi? (Taking 20% of the rated 250Wh/mi). Or do the math on the last 30miles, so the AWD could be at 177Wh/mi?
If you are saying that the AWD would be averaging 220 Wh/mi, Possibly, but I doubt it. But lets go with that number. That's a 9% difference, not 20%.
Is the tire compound (which is the ONLY negative difference between a AWD and a P), at freeway speed, going to make the same difference in consumption, as the difference between a Model 3 and a Model Y? That doesn't seem right. 4 to 5% I could buy that. Double the 9% plus a bit, not a chance.
Absolutely, did not 'FLOOR IT' at all during this trip. No need or desire to, but still got where I wanted to go early. As you can see, the car was in 'CHILL' mode. Doesn't mean I DON'T.
For me, a $10k premium to have the car I want isn't a big deal. I also didn't pay a $10k premium for the car over an AWD. For me the P3D+ has plenty of range for what I want, driving the way I want. And IF I want to stretch the range, by driving more efficiently I can.
