Draft through small triangular window next to side view mirrors
Discussion in 'Model S: Interior & Exterior' started by wormhole, Dec 18, 2013.
  1. wormhole
    wormhole Banned
    Westchester, New York
    Does anyone have this issue? If so have you got it fixed? I was told some draft is "normal" today by a local service center tech.
  2. Liz G
    Liz G P03056
    Wentzville, MO
    Yep, I've had the same problem since I got the car last Jan. They are supposed to be putting in a fix for it next week while I'm out of town. Hopefully, this fix works.
  3. jerry33
    Texas
    The Dallas Service Centre adjusted mine. No draft. Note that they adjusted it for wind noise as it was summer but had it not been done I'm sure that there would have been a draft. Now the front of the car is somewhat cold in a non-drafty way, but that's because there's nothing heating up the frunk so the heat radiates from your body to the frunk and you feel cold.
    Adjusting the fan speed to a high level helps because it pressurizes the cabin.
  4. wormhole
    wormhole Banned
    Would greatly appreciate it if you kept me posted and if they do fix it let me know what they did. I've had it in twice for the fix but to no avail. Thanks.
  5. Liz G
    Liz G P03056
    Wentzville, MO
    @Wormhole
    Some more details on my car. In addition to the draft from the triangle window, I also have cold air blowing in thru the gap around the door handles and uneven heating of the foot well, where my left foot is nice and toasty warm but my right foot is freezing. So, I was told that they were sending a number of parts to be installed in my car based on things they'd learned from the cars in cold weather climates (ala Norway). They did not specify what the parts were. Also, I was told that they had a fix for my uneven heating issue that was coming right from the engineers. So, hopefully Tesla's X-mas present to me will be a draftless car and a warm accelerator foot.
    I will gladly keep you posted on whether or not this fix works and pass along any details I can glean as to what they did to fix it.
  6. wormhole
    wormhole Banned
    LizG. Thank you for replying. I too have uneven heating in the footwell but figured it was related to the draft through the triangle window and the path of the resulting cold air. I greatly appreciate your offer to keep me posted.
  7. Musterion
    Musterion 18h 03m 37s −24° 23′ 12″
    M8
    I have this problem. Included it in my last service visit. They said they performed the "A-Pillar bulletin," test drove, and car is performing as designed. I asked what that involved and they said they add more foam tape behind the seal to make it stick out more and presumably seal to the window better. Sounded ok with me until I drove off: the problem is still there and I can still feel and hear the draft. To me there is no improvement at all. Would be interested in your feedback if you make headway on this issue!
  8. Forty Creek
    Forty Creek Member
    Carlisle, Ontario
    Yes, I have it. It's quite noticeable, but not worth at trip to the service center for that reason only. The cold foot well might be due to this also.
  9. wormhole
    wormhole Banned
    Musterion
    Thanks for the reply (btw saw pics of your car in your other post, very nice :) ), fortunately my local service center manager is as keen on solving this as I am so i will be sure to keep you posted on this.
    btw they performed the same fix on mine and while it reduced it it did my eliminate it.
  10. mknox
    mknox Well-Known Member
    Toronto, ON
    Well known issue that many have had... and had repaired by Tesla. I had it, including a small trickle of water at the car wash from that spot. Tesla replaced the weatherstripping and made some adjustments to the door. It fixed the problem there, but unfortunately I now have some wind noise from the B-pillar area that wasn't there before.:mad:
  11. strider
    strider Active Member
    NE Oklahoma
    We have a bunch of noise coming from the passenger triangle window. We're taking our car in for its annual on 1/6 and are asking them to look at it. I'll report back if they're able to fix it.
  12. wormhole
    wormhole Banned
    Interesting. Thanks for the feedback. Notice how your "fix" was different than the one above. Same company right? :).
  13. v3lzie
    v3lzie Member
    Los Angeles
    Registering so I can follow this, too. I just picked up mine this afternoon, and as soon as I was on the freeway, I heard (and can feel a draft from) those small front triangle windows.
  14. wormhole
    wormhole Banned
    Congrats on the car! Unfortunate to know that they haven't addressed this...seems to me it was a poorly engineered aspect of the car.
  15. mknox
    Toronto, ON
    I think this is more or less a fact of life with frameless side windows. You can never get as good a seal as you do with framed glass.
  16. v3lzie
    v3lzie Member
    Los Angeles
    That's kinda a cop-out; I've driven convertibles with less A pillar wind noise. I hope they come up with a good fix.
  17. teslasguy
    teslasguy MSP P#1117
    West Chester, Pa
    I had this problem last winter as did a lot of others. They fixed mine by installing a washer/shim in the window mechanism. That made the big window close tighter to the little triangle window. They said it was a
    Factory recommended fix.
  18. mknox
    Toronto, ON
    What I meant is that a frameless window is never going to be as good as framed glass in this regard. You're right in that any excessive noise should be dealt with. Mine was, and now I get a bit of B-Pillar noise.:confused:
  19. AmpedRealtor
    AmpedRealtor Well-Known Member
    Buckeye, AZ
    Slightly off topic, but if anyone is hearing a faint "whistling" noise while driving at freeway speeds it could be coming from the pano roof.
    My car developed the above noise a few weeks ago. Service told me that it was the front pano roof "fascia", the rectangular black plastic section of the roof that sits between the front of the pano roof and the windshield. Wind leaks through this area and causes whistling and increased perception of wind noise in the car. The factory approved fix involves installing brackets under the fascia to pull it down, creating a better seal and keeping air from entering that area.
  20. wormhole
    wormhole Banned
    Had this "tea kettle whistle" fixed as well.
