Drag Racing at Luskville
Discussion in 'Canada' started by Doug_G, Jul 6, 2013.
Tags:
  1. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    #1 Doug_G, Jul 6, 2013
    Had an opportunity pop up to go drag racing at Luskville with some people from the local club. The Model S did quite well, with 1/4 mile times in the 12.7 range. As soon as I did my first run a guy came out and told me I was too fast and had to run with a helmet. Fortunately I had stowed one in the Frunk just in case.
    Here are some pics and video.
    The heat and humidity wasn't helpful for the ICE cars. I did a number of runs against a very fast Saleen Mustang. The two cars were fairly evenly matched, although under the conditions I always got the faster time (although a couple of times due to reaction time he got to the finish line just ahead of me). There was a Porsche Turbo there that I didn't get a chance to run against; he was running in the 12.2's.
    Interestingly each run was slightly slower than the previous one... not sure why.
  2. dailydriver
    dailydriver Member
    Naperville IL, USA
    Thanks for sharing. How much range did you have to start and how much after your last run? I have read where the best times achieved are when the battery is at full charge and decline as range goes down.
  3. Doug_G
    Ottawa, Canada
    I arrived with about 85% charge and left with about 65% charge. So yeah it probably was the battery voltage dropping slightly.
  4. Doug_G
    Ottawa, Canada
    Here's a solo run from outside the car.
    - - - Updated - - -
    And here's one racing against the Saleen from outside the car.
  5. Zextraterrestrial
    Humboldt/Los Altos
    Standard S right? I got 12.645 with my P but you were slipping through the beginning similar to how it is when I ran so without stickier tires I think that's it on a slippery drag strip.
  6. Doug_G
    Ottawa, Canada
    It's a P85.
    Luskville is a very well-worn facility; the track is in pretty rough shape. I was getting a fair bit of wheel spin. Also it's a bit of a drive from home so I wasn't at 100% battery either.
  7. Zextraterrestrial
    Humboldt/Los Altos
    ok.
    I only ran 2 slips and 1 was a 12.64 the other 12.7 but I am spinning up to just above 45 mph or so too.
  8. eMileage
    eMileage Member
    Toronto
    Thanks Doug. Very nice, especially that high speed photo and of course the rear facing video :wink:. Congrats.
    - - - Updated - - -
    Do they have any on-site EV charging facilities? And if not, do you think they might be open to considering the installation of evChargers?
  9. Doug_G
    Ottawa, Canada
    No, there are no chargers on site. The place is pretty rustic; I think everything they have there was installed 30 years ago. I wouldn't hold my breath!
    If you want to run there, you can charge up in Ottawa (drop by our office!) or at the Hull Casino.
  10. Hamza
    Hamza Member
    Toronto
    This is great thanks for sharing.
