  • The final cut of TMC Podcast #27 is available now with topics time-stamped. We discussed: Consolidation in LiDAR manufacturers; Volvo EX90 shipping with LiDAR; FSD Beta Full Release in N.A.; FSD detecting autopilot cheats, Gwen Shotwell directly overseeing SpaceX Starship; and more. You can watch it now on YouTube. We should have it published to podcast networks shortly.
Dramatically improved efficiency from 2016 MX to 2019 MX LR LUD
Fairchild
'14S,'16 X90,'18 3, 19 XRvn, 21 Y, 2014S
Mar 27, 2016
965
1,054
Melbourne fl
Just compared the kw/mile usage on my 2016 Model X 90D(0-60 4.8) and it is 430 with my
2019 Model X LR LUD Blue Raven 100D, which was 354 kw/mile.
Wow! Considering I was the driver for each, that would imply that the new battery technology and new front motor efficiency has come a long way.
Anyone else have similar experience?
Reactions: DanCar
I don't think Performance variant is that much off from regular model.
The Main difference is that it's Raven.
I'm doing 1300 mile road trip later next month and my Nav is showing 6 charging stops only!
I had 10 for slightly shorter distance on my P90DL last year
I'm on 20s
P.S. My 80% SOC now is offering better range than 100% on old P90DL
And it's much easier to hit rated range on Raven than the older car
Saghost
8,224
7,100
Delaware
Keep in mind the Ravens haven’t seen a winter yet, so the averages will go up.
Having said that, they are markedly more efficient - my Ludicrous Raven (least efficient version with all season tires) is noticeably better than my 2016 X75D (most efficient version back then) was with the same tires.
My commute is very consistent, so it's super easy to compare
Plus, anything over 70mph on P90DL was a disaster for range. Not the case for Raven. It's easy to achieve EPA rating at that speed, which is nuts
P.S. I'll be doing 2500+ road trip, same as i did last year on P90DL (also same time). Should be good comparison
Fairchild
Mar 27, 2016
965
1,054
Melbourne fl
Of course, stealing the World SUV Speed Record from the Lamborghini Urus at Palm Beach International Raceway didn't contribute to lowering my overall kw/hour, but it sure was fun and put a check on the bucket list.
getPart
