Draw-Tite Hitch?
Discussion in 'Model S' started by iluvmacs, Jun 7, 2017.
Tags:
  1. iluvmacs
    iluvmacs Member
    Madison, WI
    Has anyone installed the Draw-Tite hitch receiver and have an opinion/review on it? It's quite a lot cheaper than the typical one from Torklift Central, so it's got me intrigued. For reference, I will only be using this for a bike rack, not actual towing. Thanks!
  2. jlv1
    jlv1 Twice as much fun
    Central MA
    I was recently looking into hitches for a bike rack, but I need a 2" receiver. etrailer has an EcoHitch for 3x the cost of that Draw-Tite: 2016 Tesla Model S Trailer Hitch | etrailer.com Seems like a lot extra.
    (BTW: my S was built in Feb 2017 -- does that make it a 2016 or a 2017?)
  3. iluvmacs
    iluvmacs Member
    Madison, WI
    They're just reselling the Torklift one.
  4. iluvmacs
    iluvmacs Member
    Madison, WI
    *Bump* Anyone?
  5. Gurujeff03
    Gurujeff03 Member
    Clovis
    The Torklift Eco-hitch is not the same as the draw tite. Obvious differences. Eco hitch is available in 1 1/4 and 2" receivers. Draw tite only 1 1/4". Eco hitch receiver is removable and the draw tite is not.
  6. iluvmacs
    iluvmacs Member
    Madison, WI
    Well aware. You didn't follow through all the context where you can buy an "EcoHitch" or the Draw-tite one from eTrailer.com. The one they call "EcoHitch" is surely just them reselling the Torklift model.
  7. rypalmer
    rypalmer Active Member
    Canada
    Doesn't look near as sturdy as the EcoHitch. The fact they have the same ratings is reassuring to me, that I chose the EcoHitch model. FTR, my hitch scrapes the ground sometimes pulling out of steep driveways. The fact my hitch receiver is removable is a big plus, IMO.
  8. iluvmacs
    iluvmacs Member
    Madison, WI
    Yeah, that was one of my concerns. No SAS on our Model S to alleviate that either.
  9. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
    I have a DT Hitch sitting in my garage to install. Have installed Torklift on two other Model S's. I have never removed the hitch receiver on any of the installs. Will pst details once installed.
  10. iluvmacs
    iluvmacs Member
    Madison, WI
    Any updates on that hitch? I gotta order one or the other post-haste.
  11. Xenoilphobe
    Not yet been on heavy business travel. May end up having to pay someone to do it
  12. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
  13. BerTX
    BerTX Supporting Member
    Texas/Washington
    It's all about the 2" receiver on the Model X. Not really related to the 1 1/4" on the Model S. The Model X owners are towing, whereas the Model S is not approved for towing.
  14. iluvmacs
    iluvmacs Member
    Madison, WI
    Yeah, I had seen that, but since it is for Model X, it didn't seem too helpful.
  15. ecarfan
    San Mateo, CA
    My apologies, when I saw your post I didn't see any mention of what Tesla you had and made the assumption that you had a Model X since that is the only Tesla model rated for towing.
    I failed to note that you had posted in the Model S forum. I also failed to read your signature which shows you have a Model S.
    Time for more coffee...
  16. yugsy
    yugsy Member
    Portland, OR
    No experience with this hitch, but it is cheap, the manufacturer gets pretty good reviews for other hitch models on Amazon, and they have free shipping today. The instruction pdf states 2.5 hours to install for a professional, and here's an installed pic they include:
  17. yugsy
    yugsy Member
    Portland, OR
    How long did it take you to install the first Torklift?
  18. Xenoilphobe
    Longer than it should have. About 4 hours.
  19. iluvmacs
    iluvmacs Member
    Madison, WI
    Given no further information on the Draw-Tite, I just ordered the Torklift one. At least there was a small discount this week for NDEW.
  20. BerTX
    Texas/Washington
    I installed the Draw-tite hitch on a refresh MS. The instructions do not cover the refresh installation, and I didn't like how they did the cutting of the hole anyway, so I was winging that part of it.
    The instructions have you cut a huge hole such that the receiver can fit through. This is needed with the Ecohitch to give access to remove the receiver. Since the Draw-tite is a fixed unit, there is no reason to leave the hole, so I modified the installation to just cut a temporary flap to put the big receiver through, then cut a chunk out of the flap and closed it around the shaft of the receiver. No hole is left. As I said, there are no instructions on where to put the hole, so I had to figure that out.
    I'll get some pictures later.
    The hitch looks ok, but I didn't buy the cargo carrier I intend to use yet, so no real testing on that. My bikes are folding ones, so I will carry them on the cargo carrier folded up, which should cause little or no increased drag.
    I have not driven a lot with the hitch installed, but have not bottomed out as yet. I'm sure it will happen eventually...
