Drive In "Low" Air Suspension Mode All The Time??
Discussion in 'Model S: Driving Dynamics' started by JohnEV, Aug 27, 2013.
  1. JohnEV
    JohnEV Member
    La Jolla, CA
    I would love to have my MS sit and ride in the "Low" suspension setting all the time; instead of having the front come up when the car is going slow. Anyway to set this up?
  2. kunal
    kunal Member
    Bellevue, WA
    You can get some drop links and then the standard setting becomes the low setting and the low setting is very low.
  3. JohnEV
    JohnEV Member
    La Jolla, CA
    Are there any threads on this? I searched and didn't find any.
    Thanks!
  4. TommyBoy
    TommyBoy Member
    Orange County, CA
    This is news to me. I thought you could set it and then it would remain that way until you manually change it. Are you saying that when moving slowly the suspension will always return to the top height? I do know that it lowers automatically at freeway speeds to reduce drag.
  5. mnx
    mnx 2013 P85
    Ancaster, Canada
    It sets itself to standard from low:
    a) when you slow down from high speed driving
    b) if you are parked in low and begin to drive off
    It never raises to High or Very High on it's own, but will lower from those settings to standard at certain speeds.
  6. lolachampcar
    lolachampcar Well-Known Member
    WPB Florida
    ..... beware using lowering links to "fool" the car lower as it may reach unacceptably low levels as it lowers further at speed.
    Also be ready to deal with much higher negative camber levels as camber gain while lowering is not a linear function.
    And, yes, I have lowering links on my car :)
  7. mnx
    mnx 2013 P85
    Ancaster, Canada
    Does lowering the car improve the handling much, or is it mostly about looks?
  8. lolachampcar
    WPB Florida
    I would say looks. Handling (1/2" lowered) seems the same although damping is a little harsher (just one data point).
