Sorry about being vague, Yes it is a “Rebuilt” title I got it from a guy who did the work in Oregon last year. Near perfect condition and had 48k miles on it with no motor noise. Shortly after it started making the milling sound at high speeds 50+ mph, I was ignorant and thought it wouldn’t disable the drive unit it would just be annoying. I was wrong.
My thoughts are that the bearings caused vibration and movement on the shaft which caused the shaft to not move in a perfect circle this caused the splines (I think it’s called runout?) to not line up and possibly break pieces of Metal off, I’m not sure but I’m hoping that it’s the bearings that gave out before the splines and gears,
All the drive units I’ve seen are on eBay and cost at a minimum of 4k$ that’s used and will have problems again. For a revision of a motor that came after 2015 (supposedly when the fixes were implemented and the motors were reliable) looking at 9k$
I want to be able to swap my own bearings and fix he issue. I don’t mind doing the work if it means protecting my investment without going car broke.
