It’s disturbing to hear, once again, the inconsistency in messaging from Service.
I just had service after a year or so of ownership. With over 25K miles, I elected to have the brake fluid flushed. That’s it. A la carte, if you will.
Was quoted $190 for the brake fluid flush and it ended up being less than that.
Replaced the wipers with Goodyears from Costco (first time trying those) to see how they last. So far they clean better than the OEM Bosch. I have a set of Bosch Ikons (which are not the OEM Bosch) in the frunk in case the Goodyears crap out early.
Next year, at 50K miles, I’ll have the battery coolant flushed and probably the brake fluid flushed again. Maybe it will be time for AC service and probably will be time for the HEPA filter replacement.
At this and every visit I confirm if any service bulletins need to be applied. For example, half shafts if you have vibration upon acceleration.
As an aside, I’ve now chosen to have all alignments and rotations/balancing handled by an independent shop.
No ever-loudening drive unit noise so far, no MCU failure, no rotor replacements (5x), no door handle sticking, and so far no 12V battery failure, unlike with the previous chariot.
There were a half-dozen or so problems identified at the factory pickup or soon thereafter, most of which have been addressed.
