It may be your battery contactors and pyro fuse. That's what mine needed with those codes.I'm having the same 2 codes on my 2015 P85DL with 20k miles. BMS_u008 and BMS_w172. I replaced the 12v battery with a the Ohmmu lithium battery. That didn't help, now it's at the SC, hope it's not the battery coolant heater...
Didn't someone say the the contractors on the Ludicrous modles had the upgraded contractors? Hopefully the SC let's me know soon... I already miss the car!It may be your battery contactors and pyro fuse. That's what mine needed with those codes.
I had the original drive unit replaced on my 11/13 built S85 a few years ago at 90K miles under warranty. I brought the car in after I received the following warnings:2015 Model S 85D. Just got this code yesterday. Swung by the service center and they looked it up real quick and it needs a new drive unit... thankfully it's under warranty otherwise they said it would've been about $9,000
One of the independent rebuilders charges ~$4k to refurb a drive unit. (Assuming no inverter damage.) I think they said that the cost for just the bearings, no labor, was ~$1,000. @ajbessinger can you confirm my recollection on that?My uneducated estimate leads me to think these units should be no more than $2K considering they are keeping the original unit as a core. Perhaps someone who has rebuilt a drive unit could chime in on the complexity, common points of failure, and input cost of refurbishment.
Yes, our price to do a rebuild is $4k, assuming that the inverter is still good, and nothing else besides bearings/seals are damaged beyond repair. We have seen drive units with worn out splines, and messed up gears, which can't be fixed short of replacing the affected parts (which of course cost's more $). While we have the Drive Unit apart, we also make a number of modifications (including some custom fabricated parts) to the Drive Units as well to prevent damage from worn out coolant seals in the future. That $4k also includes all the work to drop the subframe from the car, remove the Drive Unit, then reinstall it, etc.One of the independent rebuilders charges ~$4k to refurb a drive unit. (Assuming no inverter damage.) I think they said that the cost for just the bearings, no labor, was ~$1,000. @ajbessinger can you confirm my recollection on that?
Thanks for this additional piece of information. So the drive unit rebuild costs $2,750 and removal and reinstallation costs $1,250. That helps to understand where the costs are.If someone wants to ship us a Drive Unit on a pallet, and we just do the straight up rebuild with the modifications, that brings the cost down to about $2,750.
I'll go one further. The information about the common points of failure and preventative modifications is great knowledge for all Tesla owners to have, especially for those who plan to keep their cars beyond the warranty period. Tesla and technology in general are rather opaque so I greatly appreciate folks who can shed some light on the inner workings of these complex components.Thanks for this additional piece of information. So the drive unit rebuild costs $2,750 and removal and reinstallation costs $1,250. That helps to understand where the costs are.
Actually sitting is horrible on the seals. Then when your start driving it the seals wear fast and start leaking. I wouldn't be surprised if you have a drive unit full of coolant.I cannot fathom the drive unit could be bad at 4900 miles. This seems crazy to me
I'd be willing to be that its a drive unit issue (or if not, it could be on the horizon). As @MP3Mike said, sitting can indeed be very bad for the drive unit seals, though they also wear out over time as well with more use, so its a bit of a catch 22... Overall though, just like any other car, I'd say its way better for them to be driven regularly than not. We actually just had a car in our shop that had less than 3k mi on a new replacement motor that was put in under a year ago with the seal already starting to go bad.I found this thread helpful as I am experiencing these codes and wanted to chime in. I am not a happy camper right now as the car has under 5,000 miles. I just purchased the car a few weeks ago. The previous owner babied the car and said Tesla recently changed the 12v battery as this has extended warranty. My saga began when I went to put the car into insane + mode. About 10 minutes after engaging insane + I left and the car gave the bms_035 warning only. However this disappeared a few days later when I went to drive the car and didn’t attempt to use insane + mode. Fast forward to today, I was going to use a supercharger and the preconditioning of the battery for a few minutes may have contributed to the bms_035 message resurfacing. After this I got the dreaded limp mode bms_u008. Also got the bms_w172. I think the bms_u008 fully took out regen and the car became hard to stop. The performance also sucked at that point. Build date was 11/2015. I cannot fathom the drive unit could be bad at 4900 miles. This seems crazy to me View attachment 804719
Ah, makes sense. Must have developed an internal isolation fault. Not an uncommon fault on early battery heaters (though I don't know if I've ever seen on as new as 2015 fail). Regardless of whether or not the drive unit was the issue, you should still check out the speed sensor for signs of coolant! Even if just for peace of mind than nothing else...Update - Tesla replaced the Battery coolant heater. Kudos to Tesla Blue Ash for doing a great job. They turned this car around in under 24 hours!
Update: Errors gone - car works like normal
Yes. I was able to drive the car while the error was present and everything seemed to work fineJust like that?
I also have this exact issue with performance limit and no regen. Supercharging works fine, 12V is fine and brand new, battery heater has no problems heating battery. BMS voltages looks perfectly fine.
DU is from summer 2020 and is the Q revision.
BMS_u008_limpmode
BMS_ w172_SW_Drive_Iso_Warning
Being a Q revision, it should have the upgraded hybrid-ceramic bearings (less likely to have noise issues), but will also have the inferior single lip rotor coolant seal (more likely to develop internal coolant leak). I would definitely check your speed sensor/encoder... The "Drive_Iso_Warning" message is indicating an isolation problem (likely in the Drive Unit), which can start to pop up when coolant starts to get in there. If that is indeed the case, the codes will come back as more coolant continues to leak, and it will only get worse as more time goes by... If the coolant gets to the inverter portion of the drive unit, there is a very high likelihood that the inverter will be destroyed, so it is important to know if there's a problem before that happens (especially if you want to try and have the drive unit rebuilt).Yes. I was able to drive the car while the error was present and everything seemed to work fine
