Drive Unit Replacement
Discussion in 'Model S' started by eggy, Sep 13, 2017.
  1. eggy
    eggy Member
    Switzerland
    Question:
    I'll get a new DU for my 2014 P85+ in a couple of weeks. Which components will this encompass? Engine, inverter obviously... anything else?
    Based on experiences in this group will it be most likely one of the "next generation" with higher durability?
    Anything to watch out for particularly since my MS is a +-Version?
    Many thanks in advance for your feedback.
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    1) Motor on the left (U.S. driver side)
    2) Gearbox between the right and the left
    3) Inverter on the right
    Of those three components, which one is giving you trouble?
  3. eggy
    eggy Member
    Switzerland
    It's the known "milling sound" and "clanking", which caused Service Center to order a new DU.
  4. apacheguy
    apacheguy S Sig #255
    So Cal
    They may also upgrade your side motor mount. Please post the DU rev # once in hand.
  5. TravisT
    TravisT Member
    Kansas City, MO
    What is the "milling sound?" My CPO P85+ got a new DU installed before I took delivery ~3000 miles ago. Cruising at highway speeds, I can hear a sort of oscillating drone sound but I can't tell where it's coming from. Sounds like the front of the car though. It's a very faint sound so I haven't paid too much attention to it, thinking maybe it's normal.
  6. Tam
    Visalia, CA
    That sounds like the Gear Box.
    It will continue to work fine until the gear is all worn off.
  7. demundus
    demundus Active Member
    Oceanside, CA
    do this. then we can tell you more about exactly what they did... ie; post a picture of the invoice lol
  8. stan23
    stan23 Member
    Santa Clara, CA
    From what I read, you will get the same replacement DU. Remember, any old one they get back they just rebuild.
    The + is just suspension components. Nothing to do with the electric motor.
  9. taminatorv
    taminatorv Member
    Fremont, CA
    I just had a DU replaced because of the droning sound at highways speeds, typically over 62mph. It also got louder the faster you go. Last January, I had a DU replaced for the milling noise and noticed a slight droning sound at freeway speeds with the replacement. About 7k miles later, it got loud enough to overcome wind and tire noise. If I lifted to coast with the kW meter neutral (not using or regen), it would be completely silent. Hopefully the third DU this year is the charm.
  10. zwede
    zwede 2013 P85+
    Plano, TX
    The replacement DU will be the latest rev. I assume it's rebuilt, but they will update it with all the latest parts.
    I had the DU replaced a few months ago on my 2013 P85+ due to low speed clunking/clacking noise. My new DU was the latest rev P.
  11. TravisT
    TravisT Member
    Kansas City, MO
    How do you know the revision number?
  12. eye.surgeon
    eye.surgeon Active Member
    It will be stated on your service invoice. Mine was replaced about 3,000 miles ago for milling noise, it's been perfect.
  13. apacheguy
    So Cal
    The latest revision is Q.
  14. TravisT
    TravisT Member
    Kansas City, MO
    Oh, I don't have one of those. Mine was replaced during the CPO process.
  15. taminatorv
    taminatorv Member
    Fremont, CA
    The DU replacement in January has a different part number than the one from this month, both revision Q. I wonder what the difference is.
    January: ASY,P-TRAIN,RMN,MDLS,BASE,CMC,HS,FA2+ (1025276-00-Q)
    September: ASY,P-TRAIN,MECH,COMPLETE,RC (1002633-00-Q)
  16. appleguru
    appleguru Member
    US
    I believe the 1025276-00-Q part is remanufactured version of 1002633-00-Q.
    So it appears you got a reman unit in Jan and a new unit in Sept.
  17. Dcr3rd
    Dcr3rd Member
    DFW
    Mine was replaced today and the number is not on the RO. I inquired and was told that "We don't provide that information to our clients". So do I need to get under the car with a flashlight or what?
  18. eggy
    eggy Member
    Switzerland
    my DU got replaced today... apparently not the newest version: ASY,P-TRAIN,RMN,MDLS,SPORT,CMC,HS (1025598-00-P)
  19. TravisT
    TravisT Member
    Kansas City, MO
    I would like to know this as well. Can we crawl under the car to find a PN for our DU?
  20. zwede
    zwede 2013 P85+
    Plano, TX
    P is the newest performance DU. Q is for non-P cars.
