Driver-adjustable Regen
Discussion in 'Model S' started by Nik, Oct 5, 2011.
Tags:
  1. Nik
    Nik Dreaming no more :-(
    Cambridge, UK
    A snippet from the TTAC contributor's write-up of the Model S beta factory tour. For those who have strong opinions on the subject, this might be of interest.
    http://www.thetruthaboutcars.com/2011/10/tesla-model-s-customer-blog-beta-under-the-bright-lights/#more-413446
    Way to go with the customer feedback, but I do hope Elon isn't seeing himself as some form of replacement Steve Jobs.
  2. AnOutsider
    AnOutsider S532 # XS27
    Why Steve jobs? Because he responded to the email? I +1 adjustable regen though.
  3. efusco
    efusco Moderator - Model S & X forums
    Nixa, Missouri, United States
    That's good news. But as a "Prius Expert" the information in that statement about the Prius applying the friction brakes is completely false. It was true on the first gen prius, but since late 2003 the 2nd and 3rd gen Prius do not apply the friction brakes at all until you get below 7mph or in abrupt/emergency braking situations.
  4. Citizen-T
    Citizen-T Active Member
    Raleigh, NC
    Is it just me or are the tail lights in the first video in that article (around 20s) different from the Betas we saw on the tracks? They look more Roadster like.
  5. Nik
    Cambridge, UK
    That, and the apparent making of policy on the hoof. Do that too often and one day you come a cropper.
  6. vfx
    vfx Well-Known Member
    CA CA
    Same as the ones in the charge port door picks?
  7. TEG
    TEG TMC Moderator
    #7 TEG, Oct 5, 2011
    Yes, there was that one partially finished chassis on the factory floor with the one charge port door people could touch (although no socket behind it) and those big round (LED?) tail light fixtures. My assumption is that they are not anything that would ever see production, and were maybe just a test fixture to make sure the wiring harness could activate the rear lights. They looked like something you could buy at an auto parts store to go on a trailer:
    Or maybe those are just buried under the light reflector box that changes the shape of what you see?
  8. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Having the ability to temporarily disable regen would be wonderful for those rare times you take the car on a track. You don't want it getting in the way of cornering.
    For street driving however I'd want as much regen as they can muster.
  9. vfx
    CA CA
    This is GREAT news.
    Now to get it where it can be adjusted quickly while driving. The AC Propulsion E Box has a 4" mechanical slider on the dash. As i have said before I would love a dedicated steering wheel stalk to adjust regen radidly when approaching a traffic jam (more) driving highways (less) heading into the canyons (more) and general hypermiling (less).
    I don't think Fanz reads these boards but if there is an engineer reading this please pass it on the design team as well. :)
  10. NigelM
    NigelM Recovering Member
    Northern Virginia
    Here you go.....
  11. AnOutsider
    And the pic they posted with it:
    Seems to only show 2 settings though :(
    As an aside, is this the first official screengrab of a Model S screen? And will we have screenshotting capabilities?
  12. onlinespending
    Portland, OR
    hopefully they allow you change the suspension a bit more easily than clicking through the touchscreen menus. I can see there being times when you need to adjust it rather quickly as you approach a drive-way or speed bump as an example.
  13. NigelM
    Northern Virginia
    Dude, slow down. That's what speed bumps are for......
  14. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    I really want to know what the "Jack" button does.
  15. AnOutsider
    Probably the highest setting to allow you to easily get under it? If so though, I guess those without the air suspension are gonna have it harder.
    *edit* or maybe it disables the air suspension and rigidly locks it in place so it's not dangling as you jack the car up
  16. Zorba
    Zorba Member
    Belgium
    I think it probably is a screenshot from a computer screen.
  17. goyogi
    goyogi Member
    ::Silicon Valley:: ::Home of Tesla::
    Sure, if you know where you are going but often if you don't know the terrain and you for example have to turn into a driveway that is steep you'd want to be able to adjust it quickly instead of annoying all the people behind you. Hopefully they'll have voice control. "KITT (or HAL), raise the suspension". Or "Go go gadget suspension" :)
  18. NEWDL
    NEWDL R#350 R#1323 Sig23(traded) 8136, RWD LR 3, P3D
    NE OHIO
    The screen simulations are run on computers at Tesla. I am sure this came from one of those setups. Unless Tesla leaks how to screen shot, I doubt it will be a feature at first if ever.
    Happy to see adjustable Regen. I hope for more adjustment...
  19. Robert.Boston
    I believe that changing the suspension will require two 'button' pushes: Controls/RegenLevel. It may require a third (an intermediate Driving push) if your Controls dialog isn't on Driving already. But a voice command ("Tessie, suspension high") may be quicker.
  20. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Yes, the blog posts says that 'some will like a little more and some will like a little less.' That is not available with just two buttons. I would like to see a slider with Aggressive regen on one side, and less regen on the other.
