Driver door rubber squeaking
whenever I drive and hit a bump I hear squeaking/rubbing coming from the driver door seal near the top of the door. If I roll down the window and go over a bump, no issue.
Does anyone know of any spray or solution that can work to remove this squeaking?
I use Gummi Pflege to prevent sticking windows in Winter, but it'll work for squeaks too.
Reactions: gcmak
You can use Gummi Pflege or what I'd try to do first is just a water and a towel and give both your window edges and the rubber seals a good wipe. Do it all the way around the door and the door frame (both sets of seals).
Something else you can use to clean/protect is a bit of armor all - sprayed on a cloth then wiped (not sprayed direct onto the car/rubber). We've done this on our Camry and it works wonders. A VW golf needed something like Gummi Pflege and was super annoying haha.
