Driver side door won't open or close
Discussion in 'Model X' started by ckwong, Jun 29, 2017.
Tags:
  1. ckwong
    ckwong Member
    Northern NJ
    Just went out to do an errand and the doors where fine until 10 min later the auto-present wouldn't work, door only open 2-3 inches and had to use some force to open it. It does however latch on to close when I manually close it. From the inside using the onscreen it's the same only open 2-3 inches and I feel some kind of pressure trying to manually push it open. I try the scroll (onscreen) reset and that didn't help. I've read that some people had success unplugging a fuse but I have no idea where that is. Any suggestions? Thanks in advance!
  2. animorph
    animorph Member
    Scottsdale, AZ
    That's normal behavior if it senses an obstruction (via the falcon wing door side sensor). Our right side FWD always thinks there's an obstruction so my wife has your same problem on the passenger side. In that case it's just trying to save you from banging your door on whatever it thinks it senses. Do you have a driver's side FWD that thinks there's an obstruction (gray or red arc by the FWD when looking at the doors on the center screen)?
  3. ckwong
    ckwong Member
    Northern NJ
    I do not see any gray or red arc by the FWD door but I was checking around my settings and turned off energy saving and the door is back to normal. Not sure why that would have anything to do with the doors but I'm just happy it's back to normal as I'm going on a road trip this weekend! Thanks though!
  4. jace
    jace Member
    Chicago
    ckwong ! HUGE THANK YOU , this just fixed my brand new 75D MX driver door issue. In my case Energy Saving under Controls was OFF, I toggled on and it fixed my Driver door with the same symptom as yours.
  5. ckwong
    ckwong Member
    Northern NJ
    Happy to contribute as I have learned many many things from the super smart and wonderful people on TMC! Congrats and your new MX and welcome to TMC. This forum is the BEST!!!
  6. jace
    jace Member
    Chicago
    It felt really good informing the SC that told me to wait for a firmware upgrade on how to fix it.
    Very annoying as you take delivery and the driver feels like it's stuck in mud 2 days later.
    So glad I found TMC :)
  7. nanimac
    nanimac Aloha!
    Oahu
    I tried the energy saver fix but didn't work for me :( My door won't even stay open if I manually open it so probably mechanical issue. Bringing it in for service tomorrow.
  8. mickey6
    mickey6 Member
    Virginia
    Having the same issue. I get the "obstacle detected" for the rear drive side FWD since two days. However, the driver side only opens 2-3". At random it will open fully. There are no obstacles detected anywhere since I sometimes park in the driveway. I may try the turning the energy saving on or off. Doubt that will fix it. I have an appointment set for next Wednesday.
  9. tchaimd
    tchaimd Member
    Houston, TX
    #9 tchaimd, Sep 26, 2017
    I recently had the same issue as OP ckwong.
    The fix for me was as follows:
    1. Perform reset (using scroll wheels).
    2. Manually open driver door fully. Step out.
    3. From outside of the car, slowly close the door (over a 20 sec duration).
    4. Using FOB, lock the car, then unlock, then lock, then unlock.
    5. Push the door handle and see if it opens!
    The above steps were found in the forums and worked for me.
    Of note, before I found this fix, I called Tesla and they thought it was a mechanical problem requiring Service Center visit. I’m so glad to have avoided that inconvenience.
    • Helpful x 3
  10. hollywood
    hollywood Member
    Thank you!
