I would recommend checking your climate control settings, as this is almost always caused by incorrect climate control settings (and it isnt "turn the heat up" that fixes it).
I did a quick google to see if I could find a walkthrough on things you should be doing (service center is absolutely not what you should be doing for "my windows fog in the cold"). Here is some tips I found that I already knew, that perhaps you may not, if you are having this issue. At a high level, turning on the heat will make this worse, not better, in the cold.
How can you keep your windows from fogging up on the inside when it's cold out? See tips here.
www.toyotaofrichardson.com
How to Prevent Windows from Fogging in Cold Weather
Saturday, 07 January, 2017
In winter, it’s common for windows to fog up while drivers are on the road, which hinders visibility and safety. Not to mention that it’s just flat out annoying.
So how can you keep your windows from fogging up on the inside when it’s cold out?
First, you have to understand what causes them to fog up. Typically, it’s due to the fact that air in the cabin is warmer than the temperature of the glass windshield. Warm, humid air hits the cold surface and suddenly there’s condensation, which results in fogging.
Knowing this, there are a few easy tips you can try out to prevent your windows from fogging up in the winter:
TURN OFF RECIRCULATION
Air that’s recirculated from the cabin will have higher moisture content. Turning off the recirculation feature will bring in cooler, drier air from outside, which will help prevent windows from fogging.
CRACK A WINDOW
This is another quick way to get colder, drier air inside of the car, which will even out the temperature between your windshield glass and cabin. However, while it’s effective, you may be left feeling a little cold as a result.
COLD vs. WARM DEFROST SETTINGS
Letting your defrost run at length on a warmer temperature can help prevent fogging in many cases. However, if you haven’t been running defrost and your windows get pretty foggy, cold air is the way to go. Although you can use warm air to zap moisture collecting on your windshield, this often takes longer if the temperature conditions outside are pretty severe.
