Driver window doesn't stay up
NorCal1
35
Took delivery of MY in June. On several occasions when I activate the driver window to go up, it will go all the way up then immediately come down about 5-6". It acts as if it senses something which requires the window to come down for whatever reason. However, I have confirmed no foreign objects are in the window tract or anything else obvious causing this issue. Any thoughts or similar experiences?
jeffbco
546
291
Austin, TX
Have you tried the window reset procedure - page 15 in the owner's manual.
Johnny Vector
75
111
Maryland
Noooooo :( Didn't think to look in the manual for this type of issue. THANKS!! Will give it a try
You and me both, buddy! Fortunately I found an existing question at the top of the list when I looked here, so I didn't have to post it myself. Haha, nobody knows that I made that mis..... oh. Oops. How do I delete this?
(Also, the calibration procedure worked for me.)
Reactions: NorCal1
NorCal1
35
Happe
are you driving on rough roads when it happens? The same thing was happening to me and I realized it only occurred when I was trying to auto-close the window on relatively rough pavement. You might want to try it when the car is parked and see if it happens then.
Does it while parked. I did the window reset procedure a fews days ago and so far so good. I report back if it occurs again.
Reactions: CO_MY
