Driving a 90D in 60D mode – increased range due to reduced performance?
Discussion in 'Model S' started by JimmyMcNulty, Dec 21, 2016.
Tags:
  1. JimmyMcNulty
    JimmyMcNulty Member
    San Francisco Bay Area
    Sorry in advance if this has already been discussed, ran a search to no avail.
    I've seen a brief video posted by a good samaritan here, can't find it right now, that shows how you can make your car drive as if it's a lower performance model. So, I can drive my 90D like a 75D, 75, 60D, or 60.
    Would/should driving a 90D in 60D mode result in increased range?
  2. Derek Kessler
    Derek Kessler Member
    Cincinnati
    The 90D and 60D have the same motors. The acceleration boost comes from the voltage of the more-dense 90D battery pack, but so long as you're not mashing the accelerator every time you drive, there won't be any appreciable difference in range — just a less-punching launch from the stoplight.
  3. houstonian
    houstonian ಠ_ಠ
    Houston. Duh.
    Can't speak to the range issue but you'd probably (?) see your tires last longer if you did this all the time. That said, not sure the savings outweigh the cost in this case. o_O
  4. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I think it comes down to having a gentler foot on the go pedal, which I find particularly hard to do! But doing it really does pay off in range.
  5. zambono
    zambono Active Member
    DC
    Want to increase range and you have a heavy foot, use AP often
  6. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    ^this
  7. Max*
    Max* Charging
    NoVa
    The 90D has more battery than the 60D, hence more weight. So you can't have the same wh/mi by just a software switch calling it a 60D.
    Also, I thought they disabled the "Performance" Tesla-T tap "feature" on a recent firmware upgrade?
  8. MorrisonHiker
    MorrisonHiker S 90D 2018.24.1
    Colorado
    I tried enabling it a few days ago but couldn't get it to work. I thought I was just doing it wrong. o_O
