Driving through Water
Apr 22, 2014
19
3
Australia
This may be a question for Tesla directly - thought I'd ask the community anyway.
What are the ramifications of driving through water? I live in an area where I occasionally have to drive through water across the road. Of course I am not talking about full blown flood water, but are there any risks (to the car) associated with driving through relatively static water that is say 20cm or so deep?
Thanks
Justin
Blue heaven
Fair Dinkum Tesla
Nov 25, 2014
1,143
1,360
South West Australia
Thanks
Justin
The motor and battery are a sealed unit..BUT.... I do believe that Tesla won't warranty flood water damage, also if water is across the road there's a chance that unsighted potholes have developed, the undoing of even the best ICE vehicles, best to avoid anything above the floorpan.
also probably don't try this:
The most spectacular river crossing by car. 4x4 off road - YouTube
BenT
375
187
Adelaide, SA, Australia
Before driving through water be sure to engage lotus submarine mode.
Mark E
860
176
Sydney NSW
So long as you are sensible and it's not running water plus you know no potholes then put the suspension on very high and crawl through very slowly. This was me following a bunch of cars on the Commonara parkway a couple of weeks ago. There was an ICE stuck who probably went too fast through. ICE electrics don't like water either....
Keiron
229
17
Melbourne,australia
Might I suggest we contact the brains trust at Tesla and see if we can get a clear answer. I will start with the service centre in Melbourne but I am certain they will refer the question on to head office.
green1
4,548
1,121
Calgary, Alberta, Canada
If I recall correctly I believe the official answer from Tesla was that the fording depth for the Tesla was zero. as in not a single puddle. Now we all know this is a bit extreme, but it's certainly the easy answer from them.
Candleflame
2,390
1,100
QLD, Australia
Afaik this is all based on reports from floodings during the hurricans in the USA where electric vehicles have shown to not do so well if the batteries were submerged...
Kayto
84
29
Justin, I occasionally drive through water (creek crossing). I got the air suspension option because it goes up a bit higher than standard suspension. But I think it only puts the clearance up to around 16cm, given the style of the car.
I don't know exactly how much water I've been through, but I would never try more than 15cm. I would wait until the water goes down. Maybe a deep puddle in a pothole is ok, but I don't want to leave my car in a creek!
Driving through water can be very dangerous and should be avoided when possible.
The car doesn't seem to mind water splashing up underneath it.
sbanks
77
19
Swampscott, MA
Well, last time it rained in LA I was forced through a flooded road. Unknown to me sometime earlier I had struck road debris that cracked the battery pack... you can see how this ends...
So... beware. $22,000 for a brand new battery pack
Just curious....What did Tesla say about the cracked battery pack? I thought they warranted against anything except willful misconduct.
Skotty
2014 S P85 | 2020 3 P19"
Jun 27, 2013
2,422
1,719
Kansas City, MO
This is one area where EVs can and probably will be improved. While not as good at handling flood waters as an ICE currently, I could see some EVs (ones specifically designed for offroad use) eventually being better than ICE at handling flood waters, possibly still driveable when completely submerged (be sure to wear your diving equipment).
paulp
2,601
1,166
Adelaide, Australia
None of my cordless powertools or battery operated products (phone) seem to work after full submersion, although electric submarines seem to handle it just fine. Maybe the secret is dont wet the batteries or motor;)
Saghost
8,216
7,000
Delaware
This. There's no fundamental reason an EV can't be designed to be operated completely submerged - it just adds cost/weight and isn't useful for most people.
GM demonstrated the Volt running through a 12" (30 cm) deep water trough without issues during development - there are videos on YouTube which I may try to find when I'm back at a computer.
However, given what I've read on the flooded Tesla threads, I don't think the current Tesla cars are terribly resilient in these situations - I'd be hesitant with anything over an inch or two of standing water.
Mark E
860
176
Sydney NSW
To be blunt here, you are running a risk driving any modern luxury vehicle through standing ( and especially moving) water. You can't see what is under it in the way of holes and erosion and risk damage that way. If the water is above the sills of the car then you risk getting water inside the cabin and you would be surprised and dismayed to see the amount of electronics and vulnerable parts are at or just above floor level.
if your car gets flooded they are often written off by insurers, this is due to the ongoing issues with corrosion that will plague you. Seat motors, circuit boards, switch gear, connectors and even the wiring are not immune - especially if the water is salty.
Its not like your old 1970s or 1980s ICE in the cabin.
mriphysician
5
5
Port penn DE
Just wanted to add my 2 cents. My Tesla S85 drove through 4-6 inches - 10-12 cm of standing water in a puddle. It was a small puddle perhaps 10 feet across. The next day the tesla stopped with a message !your car may not restart. It did not restart. I had it towed to the dealer. They found water infiltration into the battery pack. Apparently some water also pooled around the main fuse for the car. It was only exposed for two days. It was a 380 fix not covered by warranty. I am crossing my fingers and hope that my car gets better. The moral of the story - do not DRIVE through more than 4 inches of standing water. Water could get into the sealed battery and also corrode the main fuse for the car. My dealer told me that this happened three other times in the past 6 months - so this is not a random or freak occurrence. PLEASE BE CAREFUL DRIVING THROUGH WATER.
