driving thru deep water puddle
Discussion in 'Model S' started by maxjamie, Mar 12, 2013.
Tags:
  1. maxjamie
    maxjamie Member
    fort walton beach, FL
    We all have experienced in occasions where intense, heavy downfalls of rain in short periods causes deep puddles of water and makes you feel a little safer driving over with SUV's or trucks. What about the S with low ground clearance and the battery tray below, anything to be concerned about driving slow over these deep water puddles?
  2. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    There's a thread here about that....
    Bottom line: avoid at all costs.
  3. Puyallup Bill
    Puyallup Bill Member
    Puyallup WA
  4. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    if you want to go swimming, go buy a range rover. Model S rims can't even handle a pothole, let alone the battery pack being submerged under water.
  5. steve841
    Ft. Lauderdale, FL
    There was a previous report of a deep water venture that caused the S to seemingly shut down for a short (pardon the pun) period of time.
    Now...how deep? How long? Don't know.
  6. Puyallup Bill
    Puyallup WA
    Well, I don't know what rims have to do with the battery pack and water, but I was under the impression that the battery was a sealed unit. Not so? I sure would hope so, and if it has active temperature control. it almost has to be sealed.
  7. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    The heat exchanger intake is down low on the Model S. Go through deep water and the wake ahead of the car will rise up and suck into the heat exchanger intakes. It's not necessarily an issue of water around the pack, but of water flowing into the heat exchanger intakes.
    I believe there's an immersion sensor near this intake that will cut power (as a precautionary measure) if water is detected spilling into the heat exchanger intake. Might just be a momentary cut, but as others have said, don't take your S for a swim.
    I survived in a low Saturn SL1 for 11 years without going through any deep water. We all can.
    - - - Updated - - -
    By the way, about 1.5 years ago my wife unintentionally drove her work car into deep standing water at night after a flash flood. Didn't see it coming, was going 50 mph, and was going too fast to avoid. The hydroplaning took her off the road and into a deep ditch, which of course was filled with water. Water rose up to the level of the steering wheel as a result. Obviously, the car was junked for insurance purposes.
    Point is, if you can avoid deep water, do. If not, you'll either have a momentary power reduction (as someone else once experienced) or if more serious...well...that's what insurance is for.
  8. Puyallup Bill
    Puyallup WA
    OK, thank you for that. It was sounding like the battery was the problem, which I couldn't quite buy.
  9. maxjamie
    maxjamie Member
    thanks for all the replies; guess better stick with SUV's on forecast day of potential flash floods
  10. Todd Burch
    Smithfield, VA
    Or just don't drive through the deep water. The simplest solution is usually the right one ;).
  11. rlpm
    rlpm S P85 | Sig X _P90D_
    Albuquerque, NM
    Does anyone else reading this thread think of Oregon Trail? If I try to ford the river, I will die of dysentery.
    Seriously, in any car, you should never try to cross standing, let alone running, water, unless you know exactly how deep it is. Or your car will have flood damage. And that's no fun.
  12. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    Stupid Q: Just go slowly and put the suspension on super-ultra-high (for those of us with air suspension, which right now is everyone, methinks)???
  13. yobigd20
    Skaneateles, NY
    http://www.teslamotors.com/forum/forums/model-s-waterproof-i-hope
  14. maxjamie
    maxjamie Member
    didn't think it was a "Stupid Q", just wanted to know how water-resistant the battery tray was if you happen to encounter unexpected puddle and unable to turn around :frown: If am not planning on just driving through any puddles like a maniac. If you raise the air suspension, doesn't that still keep the battery tray level the same and only raises the body higher ?
  15. kendallpb
    MD, USA
    #15 kendallpb, Mar 13, 2013
    I was asking if my question was stupid (hence the colon instead of period or exclamation point, and the question marks at the end of my question). ;-) I was not saying that your question was stupid.
    I thought the suspension raised everything except the tires; isn't the battery part of the body? If it doesn't raise that, then it's not nearly as useful as I thought (I thought it'd be good if I found a monster speed bump, but I'd scrape the middle part of the car if it doesn't raise everything). Hmm. Anyone else know just how it works--I haven't used it much.
  16. maxjamie
    maxjamie Member
    Kendall, my mistake for misinterpreting your response. You may be right on the air suspension issue, maybe the whole car lifts up? I don't know the answer for sure
  17. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Yes the whole body raises. And the battery is part of the body.
  18. rogbmw
    rogbmw Member
    Central Florida
    Had a friend who drove his BMW X3 into a puddle caused by a flash storm. Water was sucked into the air intake for the motor, ingested into the motor, and the motor was toast as water will not compress in the motor. All sorts of bad things happened, and this was on a normal street.
    So...it is not good to go swimming in any car:cursing:
  19. Ole
    Ole Member
    Bergen, Norway
    My first car was a SAAB 96 - the old V4 model. Not only did it float, but the air intake and all the electrical parts were above the water line. It was the only car that successfully forded a flooded road on one occasion, both going and returning. :)
  20. Todd Burch
    Smithfield, VA
    Then the water line was not high enough ;).
