Well, Roadster Forum seems a little slow so I thought I would throw in an update on my winter project.
Baker PLRC modules are very reliable and allow me to use Lotus switches. You can even pour a beer on them and they still work ...... Not that you guys would want to but testing components must cover all possibilities. The phantom drain situation on the first line MS's made me rethink my wiring and I came up with a solution that ... of course .... Made the control unit a RubGoldberg (sp?) device at best.
The switch on the right of the panel turns on the voltmeter and battery monitor. The switch on the left now is a cutoff for power to the motion sensor ( black wire) and the LEDS ( black and white wire). The Lotus switch hanging on the right of the photo is the on-off for the LEDs and will mount next to the headlight switch in the unused knock-out above the instrument cluster dimmer switch. Don't think using that space will void the warranty
I used two Baker PLRCs to make it all work.
They are the black boxes with the red light on top. I taped them together to allow them to fit behind control panel in useless storage space below trunk switch.
They entire system runs off of negative battery terminal triggers. All switches and Baker Electronix PLRC's are wired to the neg side ( black wires). The fuse block is on the positive side ( red wires). 3amp fuses for the LEDS, the Hopkins Motion Sensors base unit and the Hopkins Sensors display unit ( see post above). A 7.5 amp fuse is used for the battery charging unit......... Which I have changed from the last post.
I'll get into that later........ Still testing it. Safer interface and good strong proprietary plug system with SOC indicator ....... Which I like!
- - - Updated - - -
Anybody know if running a 12volt current thru Automotive Epoxy will start a fire:scared:
To get one wire to the battery positive terminal I needed a fuse block with only one wire out..... I emprovised!:crying:
- - - Updated - - -
Next problem!!!
Where to put LEDs! After spending time staring at 992 I realized that I can either wire the Phillips unit to the grill ( would look like the old heaps we had at the fraternity house in 1967) or double side tape them to the grill!!! No room the properly mount them .... Bummer!
Must go stare some more.:frown:
