Dry Cleaning
Discussion in 'Model X' started by Dave J, Jan 3, 2017.
Tags:
  1. Dave J
    Dave J New Member
    where do you hang your clothes from the dry cleaner? I have not found any hooks in my X. Are they hidden?
  2. outie
    outie Active Member
    SoCal
    They don't exist.
  3. travwill
    travwill Active Member
    Chicago, IL
    No hooks. I lay them down in back...
  4. FURY
    FURY Member
    DANA POINT, CA.
    The lack of clothing hook(s) seems, at first glance, an easily addressed oversight, given the model years that have elapsed, in S and X years. There must be another reason. Anyone?
    Thank you very much
    FURY
  5. HX_Guy
    HX_Guy Member
    Phoenix, AZ
    Same as travwill...I lay them flat on the trunk floor.
  6. Andersonimes
    Andersonimes Member
    Redmond, WA
  7. muleferg
    muleferg Active Member
    North Wilkesboro, NC
    Lay in back works good 4 me.
  8. vandacca
    vandacca ReActive Member
    Hamilton
    • Informative x 2
  9. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    It's not an oversight, it's intentional. Elon thought the hooks would detract from the design. I just lay the clothes on the seat. No big deal.
  10. TheAustin
    TheAustin Model X 90D (Former Model S P85)
    The Hamptons
    $30 for two hooks seems a bit pricey...
  11. vandacca
    Hamilton
    I have both the Evannex Hooks and the EV Hooks and while $30 may seem pricey, I find them much more useful than the suction cups. The EV Hooks have never fallen off and are always in place. Very solid solution.
  12. Dave J
    Dave J New Member
    I am going with removable heavy duty suction hooks $15 for two from amazon - thanks for the suggestions!
  13. drmichaels9
    drmichaels9 Member
    Newark, New Jersey
    Got the X hooks from EV Hooks for my sister. She swears by them! Definitely recommended
  14. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    It's not $30; it's $43.00 ($34.99 for the Model X hooks plus $8.00 for shipping).
    Note that the Model S hooks do not work in the Model X.
  15. ToddS
    ToddS Member
    Jupiter, FL
    I don't like those EV hooks since you have to remove them with backseat passengers. I KNOW I will forget. I like the ones that go in the window sill better.
  16. Blastphemy
    Blastphemy Member
    Los Angeles, CA
    So this company charges $8.00 for shipping something that has virtually no weight, but I did receive it three business days after my order. Note that it ships from Canada.
    Also, be aware that each hook is rated to hold 6 lbs or less, and if you're expecting a hook to hold fifteen hangers with bulky dry cleaning on them, it's not going to happen. Not sure they're worth $43 inclusive of shipping, but I guess if you're the kind of person who pays $140k+ for a car, then you won't mind for the convenience the hooks provide!
  17. Dave J
    Dave J New Member
    $15 for two free shipping with amazon prime. Worked perfectly for me. Removes easily.
    One Point Zero One 1 Pack Wall Hook Removable Vacuum Suction Hooks Bath Hook Heavy Duty Hook Hold 13LB-not suitable for paint wall
    1. [​IMG]
    2. [​IMG]
    • Informative x 2
  18. goneskiian
    goneskiian Active Member
    Bellevue WA
    If it's a few light pieces I just pull down the spring loaded plastic cover of the FWD hinge and hang them there. It does seem like if the load is too heavy it might break though so use your best judgement!
  19. zackmilo
    zackmilo Matching X+3
    Los Angeles, CA
    They sell coat hooks at Rpmtesla.com. 2 for $9
