Dual Carbon Batteries
Discussion in 'Model X' started by cmc5dc, Jul 14, 2016.
Tags:
  1. cmc5dc
    cmc5dc Member
    Bakersfield, CA
  2. Bishop
    Bishop Member
    Sc
    i actually wondered about this too .. I'm hoping by the time i have to think about it someone might have something aftermarket of it they make them drone size play with it on my drone until i commit to something larger
  3. scaesare
    scaesare Well-Known Member
    NoVA
    Well, there's lots of pie-in-the-sky in that article, but one thing that stood out:
    That's something like a 1.5C charge rate. Certainly not the "20X faster than Li-ion" the title specifies.
    Heck, superchargers today charge the Model S at ~1.5C for the initial portion of the curve, Of course, the taper ultimately requires that a full charge ends up taking something more than an hour, so if these batteries didn't require any taper that would be an improvement... just not a 20X improvement...
  4. Alketi
    Alketi Member
    Boston, North Shore
    It'd be awesome if all these breakthroughs were true, but as Elon said, you should essentially believe about 1% of what you read when it comes to battery promises. In this case, the article predicted imminent mass production and it's now 2 years later with no news.
    Also, keep in mind with charging that Tesla is currently limited at the infrastructure level, not the car. The top-line Supercharger is 120kW with 150kW planned. Beyond reasonable points, the infrastructure cost begins to get prohibitive. Tesla is already pulling a 12kV, 750kVA feed from the utility. Also, realize that 20x the charging speed while at the same voltage means 20x the current, which is unmanageable. They'd need to change the composition in such a way that increased the voltage substantially to achieve a 20x charging speed improvement.
    tl;dr Don't expect miracles regarding charging speed. There are a number of physical/cost limits in play.
    [This is back-of-the-napkin math, someone can correct the numbers if I've mangled them]
  5. vandacca
    vandacca ReActive Member
    Hamilton
    That article is over 2 years old (May 19, 2014). Old news.
  6. jelloslug
    jelloslug Active Member
    Greenville, SC
    The charging speed of the current batteries is limited by the power that can be provided, not the battery itself.
  7. David99
    David99 Active Member
    Brea, Orange County
    The utility is not even close to being the limiting factor. There are Supercharging stations with 10 stalls, meaning 5 x 135 kW total. It's the battery pack that has limitations. The cells can be charged faster but it would require more aggressive cooling and it would probably reduce battery life. Elon said the Supercharger rate is actually on the conservative side to see what the long term effects are.
  8. jelloslug
    Greenville, SC
    That's not the batteries fault, that's the cooling systems fault. You can charge virtually any type of battery almost instantly, you just need to be able to deal with the heat.
  9. Alketi
    Alketi Member
    Boston, North Shore
    By "infrastructure" I mean to include the charging station capability, which is currently limited by design to 135kW. The battery isn't the limiting factor.
  10. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    If any company knows about the latest and greatest concerning car batteries, I have no doubt that Tesla would know about it.
