Dual Charger for Facelifted Model S
Discussion in 'Model S: Battery & Charging' started by OreotheCat, May 2, 2016.
  1. OreotheCat
    OreotheCat Member
    Hong Kong
    Dear all, as I am Located in Hong Kong, the recently upgrade 72Amp is unavailable here. I would like to know that is the dual charger still available for the Facelifted Model S?
    Many Thanks
  2. MP3Mike
    MP3Mike Well-Known Member
    Oregon
    No, the facelifted Model S comes with the 48A charger and you can't add one of the old 40A style ones as a secondary. But our understanding is that you can software upgrade all the 48A chargers to 72A; for a fee of course.
  3. OreotheCat
    OreotheCat Member
    Hong Kong
    Unfortunately, 72A is unavailable in Hong Kong
  4. ddimit
    ddimit Member
    Sacramento, California, United States
    The Dual Charger was 2 40 amp chargers, I dont under stand your point if you wanted dual chargers it would be 80 amps 72 is less than 80 if the circuit is designed for 80 amps it will work for 72.
  5. OreotheCat
    OreotheCat Member
    Hong Kong
    My Model S would delivery in Mid-June, and it will be a facelifted Model S, as far as I know, the charger onboard is rated 48Amp, however, due to lack of charging station for home use in Hong Kong, I would like to install dual charger into my model S if it is available
  6. miimura
    miimura Active Member
    Los Altos, CA
    Actually, each charger in the HK Spec Model S used to be 16A 3-phase (11kW) so dual chargers were 32A 3-ph (22kW). Since the 48A/72A charger originated in the North American Spec Model X, we can only guess what they will do for the HK/UK/AUS/EU Spec Model S that has 3-phase input. If I had to guess, they will have 24A 3-ph (16kW) if you pay for the "upgrade" otherwise it will run at 16A 3-ph (11kW). Based on the North American Model S Design Studio, it looks like they are putting the 72A charger in all the cars and allowing software upgrade upon payment if you didn't configure and pay for it initially.
  7. OreotheCat
    OreotheCat Member
    Hong Kong
    Thanks for your reply, unfortunately, in Hong Kong, we do not have the option to upgrade to 72A charger
  8. Rocky_H
    Rocky_H Active Member
    Boise, ID
    Right. @miimura just said, "we can only guess what they will do for the HK/UK/AUS/EU Spec Model S that has 3-phase input."
  9. MorrisonHiker
    MorrisonHiker S 100D 2019.12.1.1
    Colorado
    It may not be available on the Design Studio now but if 72A charging can be unlocked via a software upgrade at a later date, I'm sure they'd make it available eventually.
  10. wdolson
    wdolson Supporting Member
    Clark Co, WA
    If you're scheduled for delivery mid-June, there is a good chance you have one of the last classic Model Ss built. What does your delivery specialist say? If you can't get any answers there, what was the manufacture date.
  11. OreotheCat
    OreotheCat Member
    Hong Kong
    My Model S started Manufacture by Apr 20. And from my DS, it would be the first batch of Facelifted one in Hong Kong
