Dual Chargers and Supercharging
Discussion in 'Model S: Battery & Charging' started by nleggatt, Nov 12, 2012.
  1. nleggatt
    nleggatt Member
    Abbotsford, BC
    I was thinking about getting dual chargers (I'm wanting to drive the S to Whistler or to our cabin that is a few hundred km's away) and I know that there are 80Amp chargers at both locations. The dual chargers would allow me to stop, get groceries for the weekend and recoup enough charge to get me back home a few days later.
    A few years from now I could also add the Tesla home charger and benefit from faster charging their.
    Now, my question goes to the superchargers. If I get the supercharger, do I also benefit from faster charging on the 80 Amp stations as above? Reason I'm curious is that it would make more sense to get supercharging for a few extra bucks and get the benefit of both supercharging and the twin chargers then just getting twin chargers. BUT, i dont want to loose the ability to get faster charges on non super charging stations.
    Does this make sense...
  2. SteveH
    SteveH Member
    Denton, Texas
    Supercharging and dual charging are completely independent. If you get the dual chargers then you can benefit from up to 80AC charging stations including Tesla's High Power Charger. If you get Supercharging then you can use Tesla SuperChargers. Getting one doesn't impact the other.
  3. nleggatt
    nleggatt Member
    Abbotsford, BC
    Thanks, but if I get supercharging, do I also benefit from faster charging at standard 80 Amp chargers?
  4. SteveH
    SteveH Member
    Denton, Texas
    No. SuperCharging only provides access to Tesla's SuperCharging stations. You still need dual chargers to benefit from 80A AC chargers.
  5. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    No unfortunately. SuperCharging has no bearing if you get a single or dual AC charger. To see any benefit of dual AC chargers you need a J1772 that will run at 50 amps or better. In over 13,000 miles of driving I have to find one.
  6. strider
    strider Active Member
    NE Oklahoma
    The batteries in your car are DC. Power from the wall is AC. The chargers in the car change the AC from the wall into DC for the batteries. Having dual chargers allows you to transform AC into DC at a higher rate (ie the 80A chargers). Superchargers are DC so they are bypassing the car's onboard charger(s) and going straight into the batteries. The supercharging hardware is some additional bits to manage the direct DC connection to the batteries and allow the bypass. So dual chargers have no effect on supercharging and vice-versa.
  7. nleggatt
    nleggatt Member
    Abbotsford, BC
    In BC we have 80 Amp Chargers in Hope, BC and Merrit BC, and I believe they are putting on in Whistler. They are by Sun Country I believe.
    - - - Updated - - -
    Let's try that again. Haven't replied with quote before lol.
  8. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    Or the Tesla HPWC (which is not J1772).
  9. gg_got_a_tesla
    gg_got_a_tesla Model S: VIN 65513, Model 3: VIN 1913
    Redwood Shores, CA
  10. TEG
    TEG Teslafanatic
    Do those all have Roadster plug ends on them? J1772?
  11. nleggatt
    nleggatt Member
    Abbotsford, BC
    The owner has a roadster (Drove it across Canada in the Spring), and according to what I've read in all my research, yes they are J12772 connections.
    - - - Updated - - -
    Yep, "90A Circuit Breaker. The maximum current for the vehicle is 70A,
    set by the duty cycle of the Pilot waveform."
    That's on the one that is in Merritt (not 100% if it's the same model in Hope)
  12. sanjivmodi
    sanjivmodi New Member
    I am novice when it comes to electricity calculations. I have installed 220 V 14-50 NEMA outlet on a 208 v panel, my car shows it charges at 208 v & 40 amp. giving me range of about 22 miles per hour. I drive about 120 miles per day and does not give me enough range as I can charge only every other day. My questions is if I get 220 v 100 amp. breaker, would it charge at faster rate as I do have twin chargers on board.
  13. SteveH
    SteveH Member
    Denton, Texas
    Not with a 14-50. To take advantage of higher amperage you would have to get the High Power Wall Charger (HPWC) from Tesla installed.
  14. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    And have twin chargers, though if you have your car today, you have a Sig or Founders, all of which have twin chargers.
    To the core of your problem: with 208V @ 40A, you should be getting 8.3kW/hour. If that's only 22 miles-charged/hour, it implies 378wH/mile, which is a good deal higher than 321wH/mile inherent in the 265m/85kWh EPA rating. And, there's some evidence that the "zero" mark on the Model S battery leaves the bottom 8-9kWh untapped, so the 321 is conservative.
