So I just thought I’d share.
Got a Model Y a couple-ish years ago and finally couldn’t stand driving our ICE second car any more. Just picked up a new M3 last weekend to replace it. So now we are fully de-ICEd over here ………… but I had to figure out how to charge both cars.
I live in a crummy little rented house with a single carport and was able to talk my landlord into installing me a dedicated NEMA 14-50 circuit back when I got the Y. Told her the presence of an RV plug might enhance value of home. I’ve been charging the Y with the mobile connector that came with the car (back then) ever since.
After pondering how to do two EVs I ended up with this setup. For a few days, I shared the mobile connector between the two cars ….. just plugging it into the one we weren’t using at the time. That worked, but was slightly inconvenient. I like this much better.
The Grizzl-e Duo box is pretty awesome (in my opinion):
- Pros
- No wiring required - plugs into the existing NEMA 14-50 outlet (easy peasy installation)
- Shares power between vehicles in a reasonable manner:
- 40amps to a single car if just one is plugged in and charging
- 20amps each if both cars are plugged in and charging
- 32amps to the charging car and 8amps to the non-charging car if both are plugged in and just one is charging
- 8amps each to both cars if two are plugged in and neither is charging
- Super heavy duty construction suitable for outside installation
- Easily portable
- Just one box on wall - reduced clutter and complexity
- Simple (see Cons), nothing fancy, just charges two cars. Only interaction with box is an indicator light for status of each charge circuit.
- Cons (but only if you like complicated wifi devices and need to charge two cars at once with more than 20 amps each)
- Simple - no wifi connection, no ability to control charging from box, no tracking of charge activity, etc (all of that is done/provided by cars)
- Max power to two cars limited to 20amps because sharing one circuit (plenty for overnight charging, and if you have to charge one fast just unplug the other)
