Haven't seen anyone post any numbers yet, figured I'd start a thread. Ran a couple of freeway onramps as hard as I could and generated the following on my dragy.... 3.8 3.9 4.69 Definitely not as fast as I expected, but given the not so ideal circumstances I'm fairly happy with the results. For sure I'd get numbers closer to the 3.5 and hopefully lower if I punched it down a straightaway. Freeway onramps are usually curved and or sloped to some degree. I made #9 on the American car category (populated with mostly Teslas lol)
Thanks exactly what I’ve been looking for. However I’ve been thinking how much Tesla underrated them... guess not.
3.8 up a 7% climb and round a corner is pretty good, Try riding a bike up a 7% hill to see how much difference gravity makes!
If love to see an optimal run as well. I'm not super interested in 3.8-4 for 11k.... I can't do the math on that 7%... Anyone smarter than me able to translate those numbers to a flat surface? Also I'm assuming that was uphill? If that was downhill I'm downgrading to AWD.
dragy 10Hz GPS Based Performance Meter https://www.amazon.com/dp/B077KKPMTB/ref=cm_sw_r_cp_api_i_8JXwBbD4A59A4
@forkee Thanks for posting this. If we reduce the 3.8s by the slope rate of 7% it comes in right around the advertised 0-60 (Not sure if this is correct, please chime in if you know the right physics formula): 3.8s * .93 = 3.53 It would be great to see some more tests on a completely flat smooth surface.
yikes, can't do it uphill, and don't forget dragy doesn't do 1 foot roll out, so subtract about .25.... I would like to get in one to test...
From a basic physics standpoint, the amount of force need to maintain the same speed on a hill is directly proportional to the slope %. So if you have a 7% incline, it will take 7% more force to maintain the same speed compared to a flat surface. Your calculation above is a rough estimate but doesn't take into account other car related variables when you add extra weight and drive on a curve. There's also inherent inaccuracies when calculating speed via GPS especially when driving on a curve, not to mention the elevation change calculations.
@forkee Also I forgot to ask, what was the state of charge of the battery for these runs? Most Teslas get their best results between 90-100% SOC with a warmed up battery pack (After a few hard launches)
Testing on a 7% uphill grade? That doesn't help anyone... Bad tests just spread misinformation Would love for someone to do a proper test. My Performance model is due in Jacksonville about 11 days and will do some myself if no one else can before then.
Well, for sure we'd all love to see a test where the PD isn't literally fighting an uphill battle. But putting down a 3.8 sec time given those conditions is still very helpful, as it suggests that the car is capable of outstanding performance even when things aren't perfect.
Soc was 72% Ramp was uphill. I realize conditions weren't perfect, but having some sort of numbers definitely gives an idea of the capability of these beasts. I didn't expect perfect runs the first time, which these literally are.
