My E-Z pass would never work in my Model S through the windshield. I had to fasten it behind the nose cone for it to be recognized. Wondering the Model Y has the same problem with the windshield blocking the "view" for the E-Z Pass.
That only worked sporadically on my Model 3. I ended up moving it to the glass roof just behind the center beam where I don't see it. It works every time now. YMMV. I won't be able to do that on my Model Y since there is no center beam so I'll have to play around to find the right spot. I should be getting it in the next couple days and will post back here with my findings.Install it to the right of rear mirror. It's in the owner's manual.
Same here with FasTrak. For me, it mostly doesn't read when placed to the right of the mirror. However, the only time I use the transponder is for bridge tolls and they all have cameras to photograph your rear license plate and bill your account if no transponder is detected.That only worked sporadically on my Model 3. I ended up moving it to the glass roof just behind the center beam where I don't see it. It works every time now. YMMV. I won't be able to do that on my Model Y since there is no center beam so I'll have to play around to find the right spot. I should be getting it in the next couple days and will post back here with my findings.
If it's the TxTag sticker (small) mount it as shown in the owner's manual - works great.Pumping new life into the thread.
What is the consensus of RF tag placement on Model Y ?
If you register the plate online that won’t happen.Wow. I kept holding mine up and I got two tickets, I'm surprised it works in the glovebox. I just mounted mine yesterday next to the mirror, like it said in the manual. Annoying getting tickets from EZPass when they know I own an EzPass. I had to pay $50 after they let the first one slide, on a 50 cent toll.
