ilovecoffee
Yes I remember you mentioning earlier about curing.Just dropping in to say a few things.
I wanted to echo gundarx's observation that butyl "cures" or "hardens" over time. Sounds handwavy but if you hit the road right after installing the butyl (I assume you rolled it down good onto the metal), you might actually find the boomboom improved somewhat later. Personally, I'm not sure whether my boom improved after time for curing. But it certainly didn't get any worse. In other words, if you told me the butyl curing thing is real, I'd believe you. Also, butyl rubber is apparently the same thing as chewing gum. Ever noticed how, when you spit out gum and leave it there, it gets hard after a while?
Which brings me to my next point. This past year I've been impressed again and again how much human perception of volume is relative. So if you hear the boom, then you make the whole car quieter (including the boom), then the boom may sound the same to yours ears, even though it's objectively quieter. Why does this matter? I'm almost always listening to music when I'm driving. It's rare that I notice the boom anymore after installing sound deadening like others in this thread. But if the music is off for whatever reason - boom! It's back.
Unfortunately I don't think it's going to be possible to totally silence such a heavy, cavernous vehicle that wasn't even designed as an SUV in the first place (it's a Model 3 with the vertical dimension extended). Only thing I could suggest at this point is gundarx-style insulation of the wheel wells, since he reported further reduction in noise from doing so. On the other hand, as I said, maybe if you insulate the wheel wells, you will reduce higher frequency road noise, which will make the boomboom seem louder to you. Could be counterproductive, in other words, and a lot of work just to find out you made it worse.
Edit: One last thing I forgot to mention. I am 100% sure that the boom heavily depends on the road surface. Ensure you're controlling where you test. On some roads within a few miles of my house, my car is totally silent. Others it's pure hell. Seems to have to do with the texture of the road surface more than the material it's made of, but I'm less sure about that. I'm interested to compare noise level on the hell surfaces when it's time for new tires.
I hope that's the case. I couldn't find any information online though to corroborate that idea.
And yes, concrete highways are hell.
I'd wonder if using the Model Y Shelf with some of those wall mounted foam sound absorbers (like they have in studios) on top of the shelf will reduce sound reflection in the cabin as a whole.
