PhotonMiles
Did you line the headliner plastic itself with deadener like Dynamat/ResoNix or did you just put some lightweight closed-cell foam in the cavity? The headliner itself needs to be stopped from resonating.This works minimally if at all. I pulled back the panels that you are talking about and put sound deadening material there and to fill up the space and no noticeable difference. You have to be very careful, the side window airbags are there and you don’t want to stuff it too much where it would prevent operation. I think at this point the after market coil overs (which I have on order) is the solution, if it can absorb the harsh bumps, it won’t transfer to the car’s frame then to your spine and ears.
There's already some foam back there which clearly isn't doing anything because it has no effect on frequencies so low. But perhaps some very dense material directly attached to the headliner plastic could have an effect.
