Yup. Did that too. I guess it helped some. It is no longer a loud drum when I tap on it. Like @MyEarHurts said, this is all about road noise and not the booming. I'm lucky to not have that issue. My road noise is not loud either. I just like to play around with this stuff.Has anyone insulated the top of the rear belly pan? It's yet another possible source of boominess...when I thump on it, it's quite loud.
The large subtrunk is one of the first areas I coated in butyl. I think that did nothing.Has anyone insulated the top of the rear belly pan? It's yet another possible source of boominess...when I thump on it, it's quite loud.
I just took off the right panel. Same as left but I had to remove the amplifier to get to the 3 subwoofer screws. You will need to pop out the panel near the C pillar too. Use 10mm nut wrench. Hope this helps.Today the weather was in the low 50s (in order for the glue of butyl to stick well per instruction), so I tried to do the surgery .
A couple of questions if you have the same situation:
(*j. I was only able to put the insulation on the top part of the left wheel well to the rear, and not on the side (next to the vertical panel) as there is no clearance.
(*) On the right side, the woofer box gets in the way, and I didn’t try to remove it so there is only a short part of the exposed wheel well that I can put some insulation on.
I did have some noise measurements (using my iphone) before the surgery, so I will try to measure the noise again tomorrow on the same roads. Thanks!
That misalignment could definitely make it worse. You can adjust the hatch stops now (envelope test). I would wait until after the appointment for anything more invasive. They might blame your hacks for any issues. Good luck.OMG... didn't know about this issue at all until we took delivery of our Y two days ago. Coming from a 2017 Model 3 that had been perfect to the moment we traded it in, we didn't expect any issues with the Y. Unfortunately, I didn't notice the booming sound issue at the delivery appointment until the next morning when I went to work. It's like every single road crack would cause a boom around my head.
I haven't felt the wind buffeting effect yet and not sure if it's same thing as the booming issue. Spent the whole night yesterday reading through this mega thread. Looks like I should start with the vinyl tube hack and the rigid cap hack ilovecoffee and MY-Y suggested.
Before that, I have something I'd like to check with the group here. My truck lift gate appears to be misaligned. The first two photos below are from the driver side and the last two are from the passenger side. Does it look normal to you guys? My local SC is booked all the way to Jan 12 next year. Already scheduled an appointment but wondering if I should try the hacks first or wait until they take a look at the lift gate. Really appreciate any suggestions.
Thanks Noflash. I tried the envelope test this afternoon. After the hatch stops were appropriately adjusted, that gap in the first photo looked slightly larger. And I even slipped an envelope into the trunk through that gap, which means the rubber seal is not making contact of the trunk at all in that area. Definitely need SC to realign the lift gate then. Called them again and was able to move my appointment to 1/3. Will report back after.That misalignment could definitely make it worse. You can adjust the hatch stops now (envelope test). I would wait until after the appointment for anything more invasive. They might blame your hacks for any issues. Good luck.
