That is the only way I am able to get at it. I did see one ranger reach in from above but he must have had smaller hands and I am not a big guy.I believe that you need to remove the left rear tire, and then remove the forward portion of the wheel well liner to gain access to the Service Plug.
I remove it several times a week since it is the only way to get the car to sleep. Remove the pole that holds the lid up on the driver side by removing a metal clip. Then you need a person with a thin arm to remove the orange service plug. Luckily I am such a person
Not sure if pole and lid is the correct words above, but I hope you understand although english is not my native language.
I tried to do this on a Roadster 1.5, it seemed to be a bit harder that with my Roadster 2.0.
Just "inhibit" the APS from the service menu to shut down the car. You won't risk breaking that overpriced plug.
FYI, I noticed your sig has a Model-S in it and no Roadsters. Just letting you know that this is a Roadster thread so much of this stuff won't apply to your S.
Thank you for your informative reply.
I was totally aware this was a Roadster thread but decided to learn something about them. I merely was asking what an abbreviation stood for and what the service menu was. Instead, I was cast to the side and suggested I play in my own sandbox and not yours..
I know that the owners of this forum did not create this for people to treat others like this.
Take care.
I'm trying to find the best way to reach the Service Plug on the battery. Working from the trunk is nearly impossible as you have to twist your arm completely. Anyone?
hi m0rph
nice to see you back here on the roadster forum
So you decided to keep your roadster after all ?
Was the SeC finally able to fix your car ?
cu
Bart
But you risk locking yourself out from the car...
I just did this and noticed that I was not able to use the keys FOB to unlock the car. So I had to open it from below the door to get inside.
When I went out from the car I forgot to take out the keys so now I cannot get inside again. I am searching for the extra key.
Is this normal Roadster behavour? I ask because I suspect my 12 volts system is not correct.
