Sorry if this has been asked before, but I searched and couldn't come up with anything. I've been driving a couple different M3's over the past 2 1/2 years or so. After all that time, I'm still of the opinion that the door handle design is dumb and unintuitive. Yes, I do understand how to operate it (press with thumb, grab handle with fingers), I just find it annoying that it forces me to use a certain hand (depending on which side of the car I'm on) and I also have arthritis issues in my knuckles, further complicating things.
A few months ago, someone posted on here about a brilliantly simple way to open the door: press the handle with whatever finger you want, the door releases and opens slightly, then just pull the black trim above it using your fingers (in the area just rearward of the side glass). I find it works perfectly every time on my driver's door, thankfully, but only about 50% of the time on the passenger door because the door molding is stiffer and often the door doesn't fully open. Both rear doors are even stiffer and I have about a 25% success rate. So I'm wondering, is there a safe treatment (silicon spray, etc.) that I can apply to the door moldings that isn't going to cause squeaks, whistles or other issues? I hate the idea of causing a problem, but I wish all four of my doors operated the same way. My new M3 is only a few months old, so maybe this will loosen up and fix itself over time, but I'm hoping I can help it along.
I've also noticed many times when people are getting out of the rear seats, the rear doors are so stiff they get confused how to open them. They push the button and expect the door to pop ajar... then they realize on the second or third time that they have to push the button and simultaneously push the door if they are ever getting out. This seems obvious to me, but I've seen it happen enough times that it's clearly not intuitive for some. I'm hoping adding some spray will improve this situation also.
Any suggestions?
Any suggestions?
