Easy DIY aero mod reduces wind noise and *probably* increases range
Discussion in 'Model 3: Interior & Exterior' started by ratsbew, Aug 6, 2018.
  1. ratsbew
    ratsbew Member
    O'Fallon, IL
    I simply put a run of black electrical tape along the window seams on top of the car. If you do it well, it could almost pass as a factory seal. I definitely notice a decrease in wind noise when driving and I suspect that it may add a mile or two of highway range (maybe???).
    The front is harder to make look good since it is curved. The rear seam is straight and dead easy to make it look okay.
    As for residue, just use goo-gone and it comes right off. Clean that up with some dish soap.
    The tape does contract length if you have it slightly stretched when you apply it. Aim to not have much tension on it when you apply it.
  2. Trevor B
    Trevor B Active Member
    Good DIY, but this is more elegant :)
  3. garrity
    garrity Member
  4. chilman408
    chilman408 Member
  5. garrity
    garrity Member
    As I recall they use the hollow core to better allow for temperature flexing
  6. Fusion
    Fusion Member
    San Francisco
    Wonder if they could make an official seal. Hum... would you guys buy a set if there were an option for a better looking one that kinda just snaps in and looks better than the tube?
  7. suwaneedad
    suwaneedad Member
    Atlanta
    Tubing solution looks like it will come out in a commercial car wash. ???
  8. JFW1103
    JFW1103 Member
    California, MD
    Nice find, Trevor B. I saved the link.
  9. Wubbles
    Wubbles Member
    NJ
    Is the noise reduction kit still needed on newer model 3s that supposedly addressed the wind noise issue
    And any downside in installing the kit? Is it easy to remove and reinstall for whatever reason.
  10. Narekzo
    Narekzo Member
    Beverly Hills CA
    This might be a dumb question but is there a particular reason why Tesla didn't seal that up in the first place?
