Easy DIY dash cam install
I was worried about routing the wiring but it was actually super easy the way I did it and fairly inconspicuous. I bought the Aukey DR02 4k camera since Amazon was having a sale for $70. I didn't really feel like investing that much money on a Blackvue since there isn't any solution to hardwiring it yet for motion detection aside from an expensive external battery.
I mounted the camera to the front camera/rear view mirror mount so it wasn't as obvious from the outside, I still get a perfect view from the camera.
Then I just ran the wiring inside the headliner, there's a gap so you can just tuck it in the top until you get to the side. This is the only really visible cabling that you see. If I tucked the cable in more it would create a big gap between the liners so I decided this was good enough.
I just ran the wire through the weather seals to the door jam. I need to figure out a better way to secure the wire against the inside but when you close the door there is a small gap so the wire doesn't get pinched.
I secured the cable in the footwell with some of the supplied clips. (Extra bright footwell light supplied by AO)
From the footwell I used another clip and then ran the wire on the side of the center console. Next is where we'll have to actually do a little work. The side center console trim will need to come off. It's held on by several clips so just get your fingers underneath and pry it until it pops out. It takes a little force but you won't break it, they're metal clips. I had a plastic spudger from AO that I used to installed my LED lights so it helped get it off but you don't really need it. It does help with getting the wire under the trim in the headliner though.
Once you have the side trim off you'll need a torx screw driver to remove the metal clip holder. I believe it was a T10. You don't have to take the whole thing off, I just removed the last 4 to get the wire underneath it.
Then just run the wire underneath the metal and screw it back up.
I thought I would have to trim the plastic center console a bit to get the wire to fit and still close the armrest but there is actually a small gap so no modification necessary. The only real problem is that the 12v adapter sticks out a bit and when you connect the power cable the little armrest tray will push the 12 adapter down. I just flipped the tray 180 degrees and it gave me enough room to close the armrest. I plan on getting a 90 degree adapter so I don't really have any issues.
So all in all, it took about 30 minutes. I'll clean up the wiring in the door jamb but I'm really happy with how it looks and didn't take any modification at all. The dash cam was really cheap and it's a nice piece of mind to have it in case something happens.
What do you mean by this? I thought people were already bypassing the need for an external battery by connecting it directly to their Model 3's 12V battery?
SDKoala
M3LR RWD / MYLR
Apr 11, 2018
876
989
San Diego
I installed my BlackVue cameras today, running wire to the battery pack, which I put in the in center console. I opted not to try to direct wire to the 12V battery given the possible issues people have been seeing when doing that. Anything to avoid the service center.
The molding on the side of the center console was a real pain to remove. A couple of the clips really didn't want to let go and I was afraid of breaking something. There are a few small plastic clips among the large metal ones, so it still pays off to be careful. Running the wire behind the metal bracket and into the gap for the rubber bumper in the center console works well. The power adapter for the BlackVue camera and the battery pack do not interfere with the center console tray and it fits fine in its intended orientation.
It's easy to get the wire completely behind all the trim pieces, even that space between the glove box and the passenger door. Trim removal tools are very helpful. I ran the wire for the front cam along the front of the passenger footwell and tucked it in under the bottom part of the dash molding. No clips needed.
Removing the housing for the rear-view mirror, built-in front camera, and interior camera would make for a cleaner install. I didn't want to deal with it and settled on just having them go straight into the headliner. A clip on the housing or on the glass in the corner where the housing and headliner meet might help, but it's okay for now.
There's a bit of wire showing for the rear cam, but because of how acute the angle is between the rear deck and the window, it's really difficult to work in that space and I couldn't get the wire to go behind the trim there. I was kind of fed up with it by that time because it was painful finding the right height for the rear cam to avoid installing the adhesive on a defroster line while also trying to avoid defroster lines in the camera view. Where I put it accomplishes both.
This is great. I ordered the same camera and will be receiving it soon. Unfortunately my car is still at the service center so I’ll have to wait!
View attachment 302341 View attachment 302342 View attachment 302343
View attachment 302348 View attachment 302349
View attachment 302346 View attachment 302347
View attachment 302344 View attachment 302345
How did you route the wire at the passenger door jamb? Not sure which trim pieces come off and how to get them off. Any pictures of it removed?
Reactions: drewbaumann
SDKoala
M3LR RWD / MYLR
Apr 11, 2018
876
989
San Diego
It's run in the same path as your picture. I didn't take any trim pieces off. The black trim between the glovebox and the door seal can be loosened in place. Pull it at the bottom edge near in the direction of the door seal. I think I did it with the glovebox open, which made a little more room at the bottom. It should pop loose without becoming detached completely. You can loosen it more going upward toward the A-pillar trim and make enough of a gap vertically between the glovebox and the trim to push the wire in. You can also make enough of a gap on the top edge to tuck the wire in by the A-pillar. Push on it to get it to snap back in place.
Reactions: rhaekar
SDKoala
M3LR RWD / MYLR
Apr 11, 2018
876
989
San Diego
how many feet of wire did you need to get power to the front camera? And how many for the rear? thanks
With the BlackVue, the coxial wire for the rear camera had about a 6-8 inches to spare with the rear cam at the bottom center of window and the front camera just under the rear view mirror housing. The website says it's 20 feet. I mounted the rear camera at the bottom of the window and ran the wire under the bottom trim along the driver's side the up the A-pillar into the headliner. There's would be more slack running along the top trim but I wanted to avoid the airbags. I figure an accident bad enough to deploy the airbags is one where I'd want to give the cameras the best chance to keep recording. Running the wire along the top risks it getting disconnected from the rear camera if the airbags deploy.
Plenty of extra wire for the front camera running down the passenger A-pillar, deep into the passenger footwell, and under the removable center console trim. I didn't measure how much wire I had left. Maybe about 2-3 feet out of ~15 feet.
Thanks! Worked perfectly. Now you don't see any wiring at all except at the rear view mirror going into the head liner.
