Cold weather driving in Teslas suck in terms of range. Elon lives in CA so it makes sense the car was optimized for heat.
Anyway, beam a software update that turns on battery heater and vehicle heater during limited regen.
Currently when the bat is cold, the car has zero regen. You just waste the energy in braking.
With a simple software update, you could enable some regen and use the energy to warm the bat and cabin thus bringing you into efficiency sooner and reducing energy wasted heating while accelerating.
My thought was to have a 'cold weather optimization' button that turned on features when appropriate in this way.
I would change the cabin heater algorithm so it reduced heat getting close to where you set it and allowed greater swings before kicking on. That way you have 'headroom' to turn on the heater full blast during decel.
I would also change 12v battery algorithm so it went to a lower voltage before charging off the main battery and held a slightly lower voltage during cold weather. This way you could engage the 12v charger during decel as well.
Tesla loves software improvements so here ya go.
If I was going to take cold weather further, I'd install a larger or dual battery heaters as part of cold weather packages or states and include above software changes.
