Easy way to measure Nema 5-20 120v energy consumption?
I currently charge off a Nema 5-15 120v plug at 12A. I have a roommate and I need to pay for car charging, so I'm charging through a Kill A Watt style meter. Works totally fine for at 12A and makes it easy to know exactly how much energy charging is using, including losses, preheating, etc.
There's a Nema 5-20 120v plug available as well (20A plug). I'd like to use this, but i can't finding any easy ways to measure the energy usage. Any suggestions?
12A is more or less enough to cover my driving, so I don't really needs this but if I could make it as convenient as my current setup that would be nice...
Is the problem that the Kill-A-Watt meter is limited to a maximum of 15A for current (power) measurement?
Or is the problem more simple: not being able to put a NEMA 5-15 plug into a dedicated 5-20 outlet? If that's the case, there's probably an adapter available somewhere.
edit: To clarify, a 5-20 outlet can provide up to 16A continuous. A 5-15 outlet is rated at 12A. A typical NEMA 5-20 outlet should be able to accept a 5-15 plug (that's the sideways T in the outlet).
The kill a watt device has Nema 5-15 plugs, both the male and female sides. I know physical adapters exist to connect a Tesla 5-20 adapter through to the 5-15 receptacle on the device, to let the EVSE think it's connected to a 5-20.. However, none of that is rated for 16A continuous. Would it work? Probably... but I would ideally like a meter that's rated for 16A.
Out of curiosity, why don’t you just go off the charge stats in the Tesla app? I assume the values are after-transmission-losses but I assume you could just apply a multiplier like 10% to that and be “close enough”, and the difference would be under the cost of more sophisticated measurement tools.
Reactions: Genie
You can use a clamp meter:
