Eaton Level 2 Charger
Discussion in 'North America' started by mhonig, Sep 22, 2016.
  1. mhonig
    mhonig Member
    Palm Harbor FL 34685
    Has anyone ever used an Eaton Level 2 Charger with a Tesla?
  2. AEdennis
    AEdennis Active Member
    I have with a Roadster and Model S... 30A, if I remember correctly.
    Just bring your J1772 adapter...
    Why?
  3. mhonig
    mhonig Member
    IMG_0026.jpg My home was a builder's model and the builder had installed an Eaton Level 2 Charger (the house has 60 solar panels for electric with 2 Eaton inverters). The charger is on a 20 foot cable and has this type of end, and I am trying to learn if it can be used with the Tesla with some type of adopter. It looks like this:
  4. AEdennis
    Can't tell if that's a J1772 by that picture, can you take a picture sideways?
    If you're driving an S or X, Tesla includes the J1772 to Tesla adapter. That normally would plug into one end of the charger and the other end plugs into the charging port.
  5. mhonig
    mhonig Member
    This is a photo I took at the house, but I am away until next week. I take delivery of my Model S 90 on October 6. IMG_0096.jpg
  6. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    I have one at my office. Level 2 70 amps.
  7. mhonig
    mhonig Member
    How do you connect it to your Tesla?
  8. Lloyd
    San Luis Obispo, CA
    J1772 adapter that comes with the car.
  9. mhonig
    mhonig Member
    Do you just attach the J1772 adapter to the end of the Eaton and will that plug into the Tesla, or do you use the long Tesla cable? As a newbie I have no idea where the adapter goes.
  10. mhonig
    mhonig Member
    The Eaton Level 2 Charger that I have is made for residential use. The builder had a Volt and used it.
  11. BrokerDon
    BrokerDon Member
    Newport Coast, CA
    Your Tesla should come with a charge cable & a couple of adapters including a J1772 like this:
    Tesla — SAE J1772
    ... so all you should have to do it put the above adapter on your Eaton charge cable and them insert it into your Tesla charge port.
    EASY
  12. AEdennis
    That probably is about 20 miles per hour overnight... Roughly. So, plan accordingly
  13. napoleonblownapa
    Colorado Springs, Colorado
    Note to Broker: Correct procedure is adapter into Tesla, then charging handle into adapter.
  14. Rocky_H
    Rocky_H Active Member
    Boise, ID
    Wow, that sounds very...authoritative. That is not how Tesla says to do it, so perhaps you should be a little cautious about giving such a supposed correction. In the charging video from Tesla (at 4 minutes in), it shows that you attach the adapter onto the J1772 cable, and then plug it into the charge port.
    Charging
    In reality, it makes no difference either way.
  15. Lloyd
    San Luis Obispo, CA
    Level 2 goes up to 80 amps, so that generalization is incorrect.
  16. AEdennis
    Understood, but based on what I saw from the Internet, I assumed that it's a 30A station...
