Although I have not yet received my RFMC; I´d like to bring something in discussion about a (possible) option:
* Problem:
Whenever I see charging photos on the net, many peoply try to hide there MC240 or RFMC, mostly under the car / wheel somewhere.
Why is this?
I guess because a box with light gains attraction, it is surely "more interesting" than a cable, you dont want to have people touch it (connection might come loose), and when you place it some distance away from the car, there is a risk than the next car in the next parking lot will drive over it.
* Possible solution:
(my english is very bad, but I try to explain it)
Why not offer a small metal plate, to be mounted under the diffusor, at the back of the car. Maybe painted, but should not be that visible, so maybe not necessary. Bolted with two screws on the bottom of the car.
This plate should hold two "L-Shapes profiles". Dont know if this is the correct word. In the with of the Bottom of the RFMC.
If necessary, the two profiles could "run together" a little bit, and if necessary inside the L-profiles there might be some hard rubber layer.
Goal would be that you could slide- in the RFMC top-down at the back of the car, so cable would go from the charging port to the RFMC slided in under the diffusor, and from there to the power outlet.
Ground space for the car should be higher than the RFMC, so no problem.
RFMC must not be fixed, its just a slide-in on a defined place.
As the "new" RFMC is now this kind of triangle (or whatever form), it even might be that the "L-shapes" could be designed a bit wider, and no modifications to the RFMC case are necessary!
Advantages:
- defined place for RFMC, no thoughts needed "where should I place it on the bottom?"
- looks like it is more part of the car, maybe people preventing it a little bit more from touching, also as the LEDs are invisible
- reducing risks other cars may run over it
- it is not lying on the ground! So for example, if you left the car charging alone, and it starts to rain, when the item is placed on the ground there is some risk that heavy water is coming (running) there from somewhere.
- When the item is placed top-down at the bottom of the diffusor, it is a) protected from rain from the top b) not laying on the ground, with a few cm "reserve" for water pouring down there on the ground.
Simple, but effective I think.
James, now it is up to you!
