Eberhard Wants Three Phase
widodh
Model S 85 and 100D
Jan 23, 2011
6,853
2,771
Venlo, NL
I don't think we should start this discussion again, right?
The big question I'm going to ask October 1st is the three-phase question, that really is the deal maker or breaker for me (and I guess a lot of Europeans). For now, let it be, we'll know in about a month.
Eberhard
#421 Model S #S32
Oct 17, 2010
1,147
11
Germany
I dont understand why nearly everyone in america is denying that a 3-phase grid exist there. It is there, but not everywhere. But if you see all the air cables on the east coast were the weakest point during the Hurricane Irene, there is need to change and to burry all cables into earth. But those new earth cables make only sense with 277/480V 3-phase. the distribution net works with 10.000V or even higher and are all 3-phase. We hat the same net until the 50's last century until it was upgraded to the current more efficient 3-phase 220/380V systems, the voltage increased since then to 240/400V today.
TEG
Teslafanatic
Aug 20, 2006
21,717
8,682
From a technical standpoint you could be right.
From an infrastructure expenditure standpoint it doesn't seem to be happening.
Also, we have many different interests in charge of their little piece of the infrastructure, and inability to coordinate them for upgrades makes progress slow.
Sometimes having this sort of infrastructure all under government control would make sense, but we prefer deregulation, and without a strong "business case" justification, the individual power companies just leave the old equipment in place.
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
The transmission infrastructure is all three phase, but in North America distribution to houses is pretty much all two phase. Typically only industrial parks have three phase power available to the end customer. The "last mile" is always the most expensive part of a network and therefore the least likely to be replaced.
Hurricane damage is highly unlikely to be extensive enough to require replacing all the infrastructure; in these events a relatively modest number of single point failures cause widespread outages. Indeed if the damage was so extensive as to require replacing the infrastructure, huge numbers of customers would be without power for months or even years.
widodh
Model S 85 and 100D
Jan 23, 2011
6,853
2,771
Venlo, NL
We can have this discussion over and over, to be realistic:
* 1-Phase: North America, Canada and some parts of the UK
* 3-Phase: Mainland Europe
NL, DE, BE are all deploying three-phase chargers along the road, so the Model S should take advantage of that.
Like I said before, let's wait until October 1st, I'm more then happy to ask this question to the available Tesla staff, they will have the definitive answer I guess (hope...)
Norbert
TSLA will win
Oct 12, 2009
5,410
1,626
San Francisco, CA
Tesla recently mentioned their "Charge Anywhere" philosophy. So I am sure they'll do their best to support 3-phase in Europe, and regarding 44kW, probably in so far as cost-per-car allows it (or otherwise if it can be done as an option). So far Tesla appears to do its best to support everything, while the focus is currently bringing the Model S to market.
doug
Administrator / Head Moderator
Nov 28, 2006
16,852
967
SF Bay Area
This thread was split off by one of the other moderators since Eberhard had yet again hijacked a thread to talk about 3-phase. I actually had to argue against a ban since he's been warned several times.
While I agree about the merits of 3-phase, it does not have to be rehashed in every thread.
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
That's also true in the UK...
It's not quite. You will find 3 phase on poles or in the street just about everywhere in the UK except very rural locations. The drop to the house is then typically 1 phase with groups of houses balanced across the phases. However, apartment blocks are normally fed with three phase as are some large houses. Getting three phase installed to a house is normally as simple as asking for a supply for electric heating.
In the US I understand the 3 phase is one level back, i.e. upstream of the local transformer.
jkirkebo
Model S P85+ VIN 14420 EU
Jun 13, 2010
961
12
Fredrikstad, Norway
i dont understand whats wrong giving an advice about installing a 3-phase socket in the garage when available.
Personally I don't see much point in fast home charging. I would be happy with the Leafs 3.3kW charger myself. Lack of CHAdeMO though, that's a real deal breaker.
I am actually installing an EVSE soon, LCS-25 single phase 20A. If I swap the Leaf for a Model S, that's what I'll have and use.
Jaff
3,135
318
Grimsby, Canada
Same here, but, I have had a few occasions where I was quite happy to top off my range at 70 amp (for unexpected trips) and be able to leave with a full charge earlier than later,,,
True. I've used 70A charging at home occasionally, but for the most part I charge at 40 amps and it's more than fast enough.
Eberhard
#421 Model S #S32
Oct 17, 2010
1,147
11
Germany
I have a 32A 3-phase socket installed in my garage. Its nice to be able to charge concurrent on different phases it when i have another Tesla Owner as guest.
Doug_G
Lead Moderator
Apr 2, 2010
17,877
3,337
Ottawa, Canada
Yes, it is handy, just not essential. I think there's three things that I have found 70A useful for:
1. If I want to go on a road trip, I charge in standard overnight, then when I get up I set it to Range and 70A and go have breakfast. By the time I'm ready to go it's just finished a full Range Mode charge. This minimizes the battery degradation by limiting the duration of charge > 90%. That said, to date I've only done three road trips requiring Range mode.
2. Once I had to go on a inter-city trip in the late afternoon, but didn't need Range mode. I returned home briefly and topped up the Standard mode charge before I left.
3. Tesla Toronto has occasionally brought up a Roadster for test drives, and when they do I let them use my HPC. I'm always happy to help, and besides I've got the only HPC in town!
Other than that, I probably would never notice if my charging was limited to 30A.
I suppose higher current might be more useful for the Model S. It's a larger car and takes more power for the same distance.
Talkredius
230
2
Hueckelhoven, Germany
In my case, if I would use the Roadster only as a commuter car it would be true too. I would know the distance I want to drive every day at least one month in advance :)
But I'm using it as a company car, so there are days where I arrive at 22:00 and want to leave at 05:00. And with the Model S the time for charging would be to short, HPC isn't an (legal) option, from the grid supplier point everything above 32 A has to be 3-phase => 3-phase charging is needed, or to be correct, fast charging,
Chademo would be good for public charging stations. But I heard rumors, that Chademo fast charging stations are quite expensive ( may be only at the moment ? ), 20.000 EUR for a iMiev station.
So this fast charging stations (HPC/Chademo) wouldn't be an option for average hotels too, at least not in Germany, because there are not enough EVs here, and the first mass EVs would be cars with low range, nobody will make tours with overnight stays in hotels with these cars.
But every hotel has at least [email protected] A = 10 kW, most of them also [email protected] And many of them can be convinced to install 1 oder 2 [email protected] sockets.
And if they are hard to convince we will send TRON to these hotels , he will be successful, I'm sure of that :biggrin:
=> see his Tesla goes East tour
Tesla goes east - Charge hotels - where you can charge your e-car vehicle
or see it from this point : if Model S will have 3 phase charging we would have overnight round about > 602 HPCs installed (RWE , EON, Vattenfall, Drehstromnetz + 2 in my garage, 3 phase 32 A charging points):love:
okay may be I'm a little bit off topic here but we are in the Off Topic section here :wink:
