Ceilidh
ONR is fantastic IMHO.
I have not had issues with scratches. I also think that if you properly seal your paint job when you have a new car, then any fine scratches can be into the sealant (thus easily fixed) rather than the true clearcoat or paint itself. I personally would recommend Klasse sealant layered a bunch of times (relatively easy to find) or Liquid Glass (next to impossible to find, must jump through hoops to get it to California due to CARB restrictions) which I like better. If you layer them a bunch of times when you first get your car and think of them as a paint protection scheme rather than a wax replacement when you later wash with ONR any fine swirls will be in the sealant and come right off the next time you seal it 6-12 months later depending on your taste.
I have never had issues using this sequence. As a side note, if you are inclined to use an outdoor car cover when you leave the car outside to charge for a bunch of days in bad weather, a concern frequently brought up is trapping road grit/grime under the cover and then the wind grinding it into the paint while the cover is over it. IF you follow this sealant process and carry a Kozak dry wash cloth in your car, you can use the Kozak with no water at all to wipe the grime off THEN put the cover on and remove the concern... thus protecting your paint, if you are anal like that. I sometimes resemble that comment
Hope that helps some. Just MHO.
I will second the opinion that if you are going to use ONR, you will need a crap ton of microfiber cloths and you need to switch cloths frequently as you go around the car.
Cheers.
Cheers.
