Economist: the death of the internal combustion engine
Discussion in 'Cars and Transportation' started by NigelM, Aug 12, 2017.
  1. NigelM
    NigelM Recovering Member
    Sarasota, FL
    https://www.economist.com/news/leaders/21726071-it-had-good-run-end-sight-machine-changed-world-death
    Great article, an easy read while reaffirming some simple facts....
    • Like x 5
  2. SageBrush
    SageBrush 2018: Drain the Sewer
    Colorado
    "Charging car batteries from central power stations is more efficient than burning fuel in separate engines"
    Not so clear cut.
    Central power plants that combust coal or oil are all less efficient than the Prius ICE
    Some NG plants are a good 25% more efficient than a Prius ICE, some are less.
    I love my EVs because they run off my PV. If my cars had to run off the nearby coal stack I would not be happy.
  3. kort677
    kort677 Banned
    florida.
    the ICE cars might be having "heart troubles" but they are a long way from becoming terminal. EVs in time will get larger batteries at lower costs and when you can get a decent level of charge in the same time and at as many locations that you can fuel an ICE car then the ICE cars will then be on "life support"
  4. voyager
    voyager Member
    Amsterdam, Netherlands
    Now tell Uncle Donald...
    • Disagree x 1
  5. kbM3
    kbM3 Member
    Baton Rouge
    Are you sure? Are you comparing against an Ioniq electric and accounting for all the energy requirements to refine the gasoline for the Prius (well to wheels)?
  6. bak_phy
    bak_phy Member
    New Jersey
    Probably only strictly true when coming the same fuel. E.g. It's more efficient to have a central coal power plant than to have one in every car.
  7. NigelM
    Sarasota, FL
    Saw this earlier on Twitter feed from @dpeilow :
    Pick apart the fact that these are UK based numbers, but I'll be willing to wager that even in the US emissions are significantly lower vs ICE/Diesel vehicles already and overall US power generation is getting slowly but surely greener....
