True that creep on will not remove some scenarios of unintended acceleration.
Are you kidding? It's part of the problem in most scenarios of unintended acceleration. People find the car moving, they panic, and slam a pedal.
The instant power of an electric car like Tesla though means the throttle can do much more instant damage.
Exactly, but like I mentioned with creep off if, you're moving slowly then you're hitting the accelerator. You don't slam it down in a panic because you know you're on the accelerator. The only way pedal misapplication can occur with creep off is if you're on a hill without vehicle hold. The car may start moving on its own, just like with creep. This might cause a panic and a pedal misapplication.
Make no mistake 99.99% of pedal misapplications leading to unintended acceleration (made up statistic, but likely true) are in vehicles which move by themselves when in gear. There is zero evidence that having creep off leads to a potentially unsafe condition, while the evidence is overwhelmingly the opposite.
The new Tesla firmware should help in some of these cases regardless of creep status.
Also some have mentioned gear selection, I don't consider this part of unintended acceleration. because if you hit the wrong gear and you hit the accelerator then you are intending to accelerate. With creep on and you're in the wrong gear and you accelerate in the opposite direction, if this causes you to panic then it was creeps fault in the first place.
Instead, with creep off if you're feathering the accelerator and you're going in the wrong direction you simply stop feathering the accelerator. Heck, you can even change gears right then and there without switching pedals. You have direct
physical feedback to your intended acceleration, unlike with creep on when it's handled automatically by the machine.
That said, people can do what they want. If people are used to automatics then they can turn creep on. However, they should turn it off sometime and give it try. If you can retrain your feet, it's safer in the long run. If not, then keep using creep, by all means.
