Edmunds Insideline Model S Full Test
Discussion in 'Model S' started by teslasuperfan, Sep 18, 2012.
Tags:
  1. teslasuperfan
    teslasuperfan Member
    2012 Tesla Model S Full Test
    The beat the EPA 265 mile range in two separate drives!
    They used Elon's car, the same one MotorTrend folks used in their range tests from LA to Vegas and back. Unlike MotorTrend, they drove in full comfort of the A/C and prevailing highway speeds.
    They actually think Model S is in the same class as Porsche Panamera and Maserati Quattroporte, quite a class up from Audi A6, BMW 5 series or E class.
  2. dpeilow
    dpeilow Moderator
    Winchester, UK
    Beat me by 2 mins :)
    Great review. None of the pointless "let's test the range with the air con off" crap.
  3. Adm
    Adm Active Member
    The Netherlands
    Looks like Elon thinks the performance version isn't sporty enough.
  4. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    Great review. Dan Edmunds not only got almost all of the facts correct, the article is so much better written than most of the others I've seen. It truly was a pleasure to read.
  5. AnOutsider
    AnOutsider S532 # XS27
    So, performance sport?
  6. mnx
    mnx 2013 P85
    Ancaster, Canada
    That explains why his car has the Michelin tires...
  7. Twiddler
    Twiddler Member
    DFW
    Perhaps this also explains the alcantara on the dash and the special stitching (appears to be white threads).
  8. TheAustin
    TheAustin Model X 90D (Former Model S P85)
    The Hamptons
    Edmunds Inside Line review of the Model S
    Music to my ears:
    "With 265 miles of EPA-rated range on tap, we're sitting here munching our lunch and admiring the view with a battery that's still more than half full. We'll make it home comfortably the same way we got here — at prevailing freeway speeds, with the A/C on and the stereo thumping.
    Why so confident? Because yesterday we drove the Tesla 267 miles on a single charge, and it was on our suburban city test loop, which includes plenty of stop-and-go driving along the way."
    [Insert smiley face here!]
  9. contaygious
    contaygious Active Member
    Marina, San Francisco
    Like I said in other thread they say say 12 hour charging time at 40 amp,but I thought it was about 8?
  10. mnx
    mnx 2013 P85
    Ancaster, Canada
    I'll reply here as well I guess...
    220V x 40A = 8.8kW
    85kWh / 8.8 kW = 9.65 hours... probably more like 10 hours for a full range mode charge (since it charges more slowly at the end).
  11. Bearman
    Bearman Member
    Sweden
    From the Tesla site their calculator says it takes 9:26 from completely empty to full on a range charge.
  12. kevincwelch
    kevincwelch Active Member
    Chicagoland
    This shot makes the black Model S back on the table for me. So far, colors on the table are ... all of them!
  13. contaygious
    So basically their 12 hours is way off:
    There's a catch, though, as most homes don't have the excess capacity to support a dedicated 100-amp breaker. For that reason the HPWC is compatible with service as low as 40 amps, the same as most SAE Level 2 power supplies. At this level the Model S will refill itself in 12 hours.
  14. Rifleman
    Rifleman Now owns 2 Model S's!!!
    Harrison Ohio
    I still think black is the best color on the Model S (although it does not have a bad color available to it) When I was on the list, my configuration in "My Tesla" was always black.
  15. mnx
    mnx 2013 P85
    Ancaster, Canada
    a 40A breaker can only be used @ 32A continuous. That is where they are getting 12 hours from. :)
  16. vfx
    vfx Well-Known Member
    CA CA
    Every time you change your mind on your color you should change you avatar car color so we can keep track!
  17. kevincwelch
    Chicagoland
    Well, I don't have enough time to change my avatar that frequently. :tongue:
  18. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    Tesla needs a media relations person who can clearly communicate charging information to the media...as this will affect sales to some degree for a technology misunderstood or not understood by the majority of the world. They need to communicate:
    -Vast majority of drivers are fine with a NEMA 14-50 which can be installed for as little as $50 and as much as about $1K depending on length of line run, expertise of the homeowner, etc.
    -Supercharger network of high speed chargers is coming soon.
    -HPWC/100A connection is only needed for those who nearly deplete their battery and need a "quick turnaround" on the car.
    It's the little things like this that get lost on the "non-believers" and end up dominating comments sections of website articles.
    - - - Updated - - -
  19. chrisn
    chrisn Member
    Review doesn't actually say this. They use the Panny GTS for performance compare and mention that the car is as big as a Quattroporte, but they don't make any qualitative comparison to the other cars you mention.
