It seems there is real gain in acceleration for LR RWD, 0-60 coming in at 5 sec, a 0.3 sec gain, and quarter mile 13.5 [email protected] gain is only 0.1 sec.
I've seen a few of these videos, still not a huge fan of how they're represented, we have to make some assumptions that the testing is fair.
One thing in Tesla testing favor here is that EVs aren't particularly impacted by temperature changes, humidity changes, etc.
However, their (and others) testing still doesn't address a lot of possible variability:
1. Tire condition for launch (probably not huge given AWD and how much Tesla hooks), however, warmer ground temp makes a big difference. Considering it's now May, likely they tested the original test when the ground temp was much cooler.
2. SoC for the tests. Even 10% battery change can have large differences.
3. Winds can change performance significantly.
I really want to see a test that is effectively the following:
1. Tesla shows new update available, tester doesn't update. Battery at 90% SoC.
2. Tester runs 1/4 mile tests (average of 3)
3. Tester immediately performs update
4. Tester charges car back to 90% SoC
5. Tester runs second 1/4 mile tests (average of 3)
Assumption above: Weather/Wind hasn't changed
That's the fairest and closest test. It sounds like this test had months in between them, the variability of 0.1 seconds in a 1/4 mile is within the margin of tire/wind differences. Given the minimal power change, any test not done back to back at any different SoC isn't really valid.
Would you mind sharing any links to credible videos which tested the difference before and after?I was more impressed how they rushed out this breaking news weeks after YouTube was flooded with far superior videos.
That's what originally quoted by Tesla in 2017. Now, there is no spec anywhere telling what is actual HP.Where'd they get that 258hp number? Don't most dynos show the car to actually be around 325 peak?
Again, what is quoted and what you get may be different. Many BMWs are under rated for example by sizable margin.
Edmunds car is 2017 LR RWD, not AWD car.I thought that was for LR-RWD, and I thought Edmunds was using LR-AWD which I understand to have horsepower closer to 350. I kind of felt LR-RWD = 250, LR-AWD = 350, PERF-AWD = 450 before. Those are just estimates but almost a 100 hp difference between levels. I don't care enough to research it.
I get paid too much to do your research for you. However, I can direct you to Youtube.com, where the search bar will fulfill your every fantasy, for free.Would you mind sharing any links to credible videos which tested the difference before and after?
Yeah, your statement is funny. All those are amateur video without proper test equipment, and none I saw are for RWD either.I get paid too much to do your research for you. However, I can direct you to Youtube.com, where the search bar will fulfill your every fantasy, for free.
Oh ya, because that useless Edmunds video really set the bar for controlled scientific testing.....perhaps you should try and focus on the ACTUAL POINT that I made; that the Edmunds video is a little late to the party.
Clearly you have NO idea what equipment DAErik uses.
Regardless of what you think of DAErik's video, it beat Edmunds to market by 30 odd days. That's the ACTUAL POINT.
Oh, and I can explain why almost all of the videos don't feature the lowest performing RWD model.
I tossed mine, front and rear, when I got it wrapped. I would have gotten rid of it earlier if I hadn't already planned when it was wrapped.Interesting they shaved the T badge off the hood.
